- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.11
2023.10.11 release notes for Automation Suite on EKS/AKS.
Release date: September 24, 2025
What's new
This Automation Suite version brings various small bug fixes and improvements.
Bug fixes
- We have fixed an issue that prevented log forwarding when using S3 endpoints in non-AWS format (that is, without
.amazonaws.comin the URL), as the endpoint was not in the format expected by Fluentd. - An issue prevented Velero backups from completing successfully. A
FailedValidationerror message was displayed, indicating that no default backup location could be found. This issue occurred because Velero could not locate a default backup storage location when thespec.defaultfield was missing in theBackupStorageLocationconfiguration.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.11.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ✅ New: 2023.10.11 | Action Center release notes |
| AI Center | ✅ New: 2023.10.11 | AI Center release notes |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ✅ New: 2023.10.11 | Apps release notes |
| Automation Hub | ✅ New: 2023.10.11 | Automation Hub release notes |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Data Service | ✅ New: 2023.10.11 | Data Service release notes |
| Document Understanding | ✅ New: 2023.10.11 | Document Understanding release notes |
| Insights | ✅ New: 2023.10.11 | Insights release notes |
| Orchestrator | ✅ New: 2023.10.12 | Orchestrator release notes |
| Process Mining | ✅ New: 2023.10.11 | Process Mining release notes |
| Task Mining | ✅ New: 2023.10.11 | Task Mining release notes |
| Test Manager | ✅ New: 2023.10.11 | Test Manager release notes |
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.26.3 |
| ArgoCD | 3.0.11 |
| Prometheus | 3.5.0 |
| Grafana | 12.0.2 |
| Fluentd & Fluent-bit | logging-operator: 6.0.1 fluent/fluent-bit: 4.0.3 |
| Gatekeeper | 3.20.0 |
| Cert-Manager | 1.18.2 |
| Velero | 10.0.10 |
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
