- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.12
2023.10.12 release notes for Automation Suite on EKS/AKS.
Release date: November 6, 2025
This release brings security updates to address CVE-2025-55315.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.12.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ✅ New: 2023.10.12 | Action Center release notes |
| AI Center | ✅ New: 2023.10.12 | AI Center release notes |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ◆ Bundled: N/A | N/A |
| Automation Hub | ◆ Bundled: N/A | N/A |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Data Service | ✅ New: 2023.10.12 | Data Service release notes |
| Document Understanding | ✅ New: 2023.10.12 | Document Understanding release notes |
| Insights | ✅ New: 2023.10.12 | Insights release notes |
| Orchestrator | ✅ New: 2023.10.13 | Orchestrator release notes |
| Process Mining | ✅ New: 2023.10.12 | Process Mining release notes |
| Task Mining | ✅ New: 2023.10.12 | Task Mining release notes |
| Test Manager | ✅ New: 2023.10.12 | Test Manager release notes |
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.26.3 |
| ArgoCD | 3.0.11 |
| Prometheus | 3.5.0 |
| Grafana | 12.0.2 |
| Fluentd & Fluent-bit | logging-operator: 6.0.1 fluent/fluent-bit: 4.0.3 |
| Gatekeeper | 3.20.0 |
| Cert-Manager | 1.18.2 |
| Velero | 10.0.10 |
