- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.3+patch2
2023.10.3 Patch 2 release notes for Automation Suite on Linux.
Release date: July 5, 2024
About this patch
Erratum - added July 26, 2024: We have removed the download links for the Automation Suite 2023.10.3+patch2 artifacts from the Automation Suite on Linux Installation Guide because the patch did not work as intended.
The fixes included in Automation Suite 2023.10.3+patch2 will also be available in Automation Suite 2023.10.3+patch3 and 2023.10.5. We recommend that you wait for Automation Suite 2023.10.5 to get the fixes.
This release applies a patch to Automation Suite 2023.10.3. The patch includes fixes to various issues in Apps and addresses some document validation tasks not being displayed accurately in Action Center.
For more details, see the individual product release notes referenced in the Product versions section.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
| DISCOVER | BUILD | MANAGE | ENGAGE |
| Automation Hub 2023.10.3 | Automation Ops 2023.10.3 | AI Center 2023.10.3 | Action Center 2023.10.3-patch1 |
| Task Mining 2023.10.3 | AI Computer Vision 2023.10.2 | Insights 2023.10.3 | Apps 2023.10.3-patch1 |
| Process Mining 2023.10.3 | Document Understanding 2023.10.3 | Orchestrator 2023.10.4-patch1 | |
| Test Manager 2023.10.3 | |||
| Data Service 2023.10.3 |
Internal third-party component versions
This Automation Suite release bundles the following internal components:
| Component | Version |
| RKE2 | 1.26.11 |
| ArgoCD | 2.7.7 |
| logging-operator | 4.1.0 |
| logging-operator-logging | 4.1.0 |
| gatekeeper | 3.12.0 |
| rook-ceph | 1.9.4 |
| prometheus-pushgateway | 2.1.6 |
| cert-manager | 1.12.3 |
| rancher-istio | 102.2.0-up1.17.2 |
| rancher-logging | 102.0.1-up3.17.10 |
| rancher-logging-crd | 102.0.1-up3.17.10 |
| rancher-monitoring-crd | 102.0.1-up40.1.2 |
| rancher-gatekeeper-crd | 102.1.0-up3.12.0 |
| rancher-gatekeeper | 100.2.0-up3.8.1 |
| rancher-monitoring | 102.0.1-up40.1.2 |
| longhorn | 1.4.3 |
| longhorn-crd | 1.1.100 |
| reloader | 0.0.129 |
| csi-driver-smb | 1.10.0 |
| velero | 3.1.6 |
| redis-operator | 7.4.2-54 |
| redis-cluster | 7.4.2-2 |
