- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.12+patch1
2023.10.12 Patch 1 release notes for Automation Suite on EKS/AKS.
Release date: December 4, 2025
About this patch
This release applies a patch to Automation Suite 2023.10.12. The patch addresses some issues in Document Understanding. For more details, see the individual product release notes referenced in the Product versions section.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
The following table outlines the release status, version, and release notes for all UiPath products deployed under Automation Suite 2023.10.12+patch1.
Legend:
✅ New: This Automation Suite version includes a new product version. New release notes are available.
◆ Bundled: This flavor includes a previously released product version. No new release notes are available.
| Product | Version | Release notes |
| Action Center | ◆ Bundled: N/A | N/A |
| AI Center | ◆ Bundled: N/A | N/A |
| AI Computer Vision | ◆ Bundled: N/A | N/A |
| Apps | ◆ Bundled: N/A | N/A |
| Automation Hub | ◆ Bundled: N/A | N/A |
| Automation Ops | ◆ Bundled: N/A | N/A |
| Data Service | ◆ Bundled: N/A | N/A |
| Document Understanding | ✅ New: 2023.10.12-patch1 | Document Understanding release notes |
| Insights | ◆ Bundled: N/A | N/A |
| Orchestrator | ◆ Bundled: N/A | N/A |
| Process Mining | ◆ Bundled: N/A | N/A |
| Task Mining | ◆ Bundled: N/A | N/A |
| Test Manager | ◆ Bundled: N/A | N/A |
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.26.3 |
| ArgoCD | 3.0.11 |
| Prometheus | 3.5.0 |
| Grafana | 12.0.2 |
| Fluentd & Fluent-bit | logging-operator: 6.0.1 fluent/fluent-bit: 4.0.3 |
| Gatekeeper | 3.20.0 |
| Cert-Manager | 1.18.2 |
| Velero | 10.0.10 |
