  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
2023.10.4
Release date: June 27, 2024
New prerequisite checks
We have introduced more prerequisite checks to optimize the overall experience of installing and configuring Automation Suite and to catch missing requirements earlier. Here are some highlights:
  • Automation Suite now checks if the external objectstore supports POST requests to buckets via pre-signed URLs. Document Understanding requires POST request support to download files from the buckets.
  • We have introduced new prerequisite checks in the mirror-registry.sh and hydrate-registry.sh scripts. These checks validate that you have enough free disk space for Docker (under /var/lib/docker) and Podman (under /var/lib/containers) before mirroring or hydrating the registry. Additionally, you are prompted with a message to either continue or abort if you do not have sufficient resources.
Updated Podman version
We have updated our RPM package requirements, with the minimum supported Podman version now being 4.0.2.
Support bundle tool improvement
We have improved the Automation Suite support bundle tool capabilities. Now, the tool extracts all the config maps data from your cluster. The new capability allows you to use more valuable data sets for troubleshooting purposes.
Support for external registries that require projects
We are happy to announce that Automation Suite now supports Harbor and other external registries that require you to create a project before pushing or pulling images from the registry.
Improved UiPath Automation Suite Install Sizing Calculator
We're happy to announce various fixes and improvements that ensure an even more accurate estimate of the hardware requirements for any Automation Suite deployment. The tool now takes into account the additional data disk required by AI Center and Document Understanding. Also, it now takes a single click to share the UiPath Automation Suite Install Sizing Calculator URL along with your currently selected configuration.
If you want to take the UiPath Automation Suite Install Sizing Calculator for a spin, see Capacity planning.
Improved accessibility
We have made several accessibility improvements as part of our commitment to develop inclusive technology for our users.
Bug fixes
  • Erratum - added February 27, 2025: We fixed an issue that was preventing document validation tasks, specifically those involving the IsEmpty business rule, from being displayed accurately in Action Center.
  • Erratum - added February 27, 2025: In Apps, preview and publish of VB expression apps were not working. We fixed this issue.
  • Erratum - added February 27, 2025: In Apps, uploads and downloads of images or documents failed in proxy environments for all apps. We fixed this issue.
  • When generating the support bundle, an incorrect FQDN was used for AKS on Azure Government. We have fixed the issue.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Upgrade failure due to overridden Insights PVC sizes
Erratum - added December 18, 2024: An issue causes upgrades to fail when the existing Insights PVC sizes are inadvertently overridden. To address this problem, you must manually change the PVC sizes in ArgoCD UI. For details, see the Troubleshooting section.
This issue is fixed in Automation Suite 2023.10.7.
Data loss when reinstalling or upgrading Insights following Automation Suite upgrade
Erratum - added December 18, 2024: Following an Automation Suite upgrade from version 2023.4 or older, reinstalling or upgrading Insights results in data loss due to an issue with Insights storage class changes. To address the problem, see Troubleshooting.
We fixed the issue in Automation Suite 2023.10.7.
Node maintenance issue in non-HA Redis
Erratum - added December 18, 2024: An issue causes the redis-cluster-0 pod to get stuck in the terminating state when you perform a node drain in non-HA Redis scenarios. To address the problem, you must force delete the pod using the following command:
kubectl -n redis-system delete pod redis-cluster-0 --force
Unnecessary Redis DNS resolution validations during Active/Passive checks
Erratum - added December 18, 2024: An issue causes unnecessary Redis DNS resolution validations for redis.<primary-fqdn> and redis-db.<primary-fqdn> during Active/Passive prerequisite checks. This issue is fixed in Automation Suite 2023.10.7.
Insights annotation issue blocks installer
Erratum - added December 18, 2024: An Insights annotation issue blocks the Automation Suite installer. We fixed the issue in Automation Suite 2023.10.7.
RKE2 log collector runs indefinitely
Erratum - added December 18, 2024: The RKE2 log collector runs indefinitely for some system commands. We fixed the issue in Automation Suite 2023.10.7.
Unintended RKE2 service upgrade on additional nodes
Erratum - added November 26, 2024: We have identified an issue where exclude= rke2-* is not added to the /etc/yum.conf file on nodes other than the first server. In specific environments, particularly online ones, an attempt to upgrade all components can cause an unintentional upgrade of the RKE2 service on nodes other than the first server.
To fix this issue, you must manually add exclude=rke2-* to the /etc/yum.conf file on all the nodes of your Automation Suite cluster.
AI Center skills sync failure during side-by-side upgrade
Erratum - added December 18, 2024: A syntax issue causes the failure of the aicenter skill sync and aicenter skill status commands during a side-by-side upgrade.
To fix this issue, you must manually edit the syntax. For details, see the Troubleshooting section.
Test Automation SQL connection string is ignored
Erratum - added October 17, 2024: When you provide an SQL connection string under the orchestrator.testautomation section of the cluster_config.json file, the uipathctl binary ignores the connection string and uses the one under the orchestrator section instead. To address the problem, see the Troubleshooting section.
Enabling Connaisseur causes installation or upgrade failures
Erratum - added October 17, 2024: An issue causes installation or upgrade failures when enabling Connaisseur during the configuration of an external OCI-compliant registry. The isssue occurs when you set the registries.trust.enabled parameter to true in the cluster_config.json file.
OSD PV resize does not persist after upgrade
Erratum - added October 17, 2024: If you resize the rook-ceph OSD PV, the new size does not persist following an Automation Suite upgrade. We fixed the issue in Automation Suite 2023.10.6.
Redis failures due to inconsistent password updates
Erratum - added October 17, 2024: An issue is causing Redis recovery job failures when you update the ArgoCD admin password directly through the UI without simultaneously updating the Kubernetes secrets as well. To prevent the issue, we highly recommend that each time you change the ArgoCD admin password via the UI, ensure that you update the Kubernetes secrets at the same time. For more details on how to properly update the ArgoCD admin password, refer to Troubleshooting.
Installation fails while populating node labels
Erratum - added October 17, 2024: When deploying Automation Suite on AWS machines where only IMDSv2 is enabled, installation fails while populating node labels. To address the issue, see the Important note in Optional: Enabling resilience to zonal failures in a multi-node HA-ready production cluster.
Resized PVC upgrade issue
Erratum - added October 17, 2024: An issue is causing problems in the upgrade process if you have resized the Docker-Registry PVC used by your in-cluster Docker registry. Specifically, the resized PVC is not accurately recognized during upgrades. We fixed this issue in Automation Suite 2023.10.6.
Pods cannot communicate with FQDN in a proxy environment
Erratum - added October 17, 2024: In a proxy environment, if the proxy server uses the same port as the TCP port of any other service in the Istio service mesh, such as port 8080, pods cannot communicate with the FQDN. The issue causes the following error:
System.Net.Http.HttpRequestException: The proxy tunnel request to proxy 'http://<proxyFQDN>:8080/' failed with status code '404'.
To fix the issue, see the Troubleshooting section.
Registry configuration corruption during upgrades
Erratum - added October 17, 2024: An issue causes the corruption of the registry configuration during the upgrade process. The issue occurs when uipathctl mistakenly processes ports in helm URLs as external registries, excluding the insecure_skip_verify: true parameter from the registries.yaml file. To overcome this issue, you must manually include the parameter in your registries.yaml file. We fixed this issue in Automation Suite 2023.10.6.
Intermittent not ready reports from agent machines
Erratum - added October 17, 2024: An issue causes agent machines to intermittently report as not ready when the rke2-server service is shut down without executing the rke2-killall.sh script. We fixed this issue in Automation Suite 2023.10.6.
AI Center issues with external Orchestrator and Identity Service
Erratum - added September 11, 2024: There are several bugs in AI Center when connected to an external Orchestrator and Identity Service, causing issues during setup in the following situations:
  • During the installation of Orchestrator certificates for trusted communication.
  • When setting up an Identity Service client for Document Manager.
  • When configuring an Identity Service client for metering services.
To address the issues, you can apply Automation Suite 2023.10.4+patch2. The fix will be included in all future releases, starting with Automation Suite 2023.10.6. We recommend that you wait for Automation Suite 2023.10.6 to get the fix.
Weak ciphers in TLS 1.2
Erratum - added August 29, 2024: We have identified certain vulnerabilities associated with the usage of weak ciphers in TLS 1.2. For details on how to mitigate the issue, see How to address weak ciphers in TLS 1.2.
Cannot upgrade due to failed jobs in system-upgrade namespace
Erratum - added August 26, 2024: Upgrading Automation Suite fails due to the presence of failed jobs in the system-upgrade namespace. If the upgrade command fails at any stage (infra, fabric, or service upgrade), take the following steps before retrying the upgrade:
  1. List the existing jobs in the system-upgrade namespace:
    kubectl get jobs -n system-upgrade
  2. Delete the failed jobs:
    kubectl -n system-upgrade delete jobs <failed_jobs>
When running the command, replace the <failed_jobs> placeholder with the names of the failed jobs, separated by spaces.
We fixed the issue in Automation Suite 2023.10.5.
Automation Suite 2023.10.3+patch1 issue
Erratum - added August 8, 2024: The bug fix related to document validation tasks in Action Center from Automation Suite 2023.10.3+patch1 was not included in the Automation Suite 2023.10.4 release. We recommend that you wait for Automation Suite 2023.10.5 to get this fix.
Support bundle log collection failure
Erratum - added August 14, 2024: An issue affects the support bundle generation when using an external OCI registry in an offline environment. Under these conditions, the generated support bundle lacks historical logs and cannot upload to any selected external object storage. To fix this issue, see the Troubleshooting section.
Upgrades fail due to Longhorn being uninstalled
Erratum - added August 14, 2024: Upgrading from Automation Suite 2023.10.x fails due to the Longhorn storage classes still being present. To solve the problem, you must clean up the Longhorn storage classes manually, by running the following command:
  for sc in $(kubectl get sc -o json | jq -r '.items[] | select(.provisioner=="driver.longhorn.io") | .metadata.name'); do
    kubectl delete sc "${sc}"
  done
  done
Unnecessary ListBucket API prerequisite check fails for external objectstore
Erratum - added August 14, 2024: For AI Center and Task Mining, the ListBucket API prerequisite check fails when using an external objectstore. However, AI Center and Task Mining do not use the ListBucket API permission. We removed the unnecessary check in Automation Suite 2023.10.5.
Cannot enable SSO for ArgoCD
Erratum - added August 14, 2024: You cannot enable SSO for ArgoCD due to an issue with the Dex image versions. We fixed the issue in Automation Suite 2023.10.5.
snapshot-controller-crds pod in CrashLoopBackOff state after upgrade
Erratum - added August 14, 2024: An issue causes the snapshot-controller-crds pod to remain in the CrashLoopBackOff state after upgrade. This occurs due to a conflict between the newly installed snapshot-controller and the existing one during the RKE2 upgrade. To fix the issue, see the Troubleshooting section.
Installation fails due to telemetry checks
Erratum - added August 14, 2024: In certain conditions, the Automation Suite installation process can fail due to telemetry check errors. To fix this issue, you have to manually set the telemetry check as optional and restart the installation. Starting with Automation Suite 2023.10.5, telemetry check errors no longer disrupt the installation process.
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2023.10.11.
GPU enablement fails with external registries containing project names
Erratum - added September 24, 2025: An issue prevents GPU enablement after adding a GPU node when using external registries with project names (such as Harbor). The required pods do not start and display an ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
  -n kube-system \
  nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>
  -n kube-system \
Orchestrator does not start when using user-assigned managed identity
Erratum - added September 24, 2025: An issue prevents the storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, Orchestrator cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
  1. In the ArgoCD Orchestrator application, go to Details > Parameters.
  2. In the values text box, set storage.isExternal : true and save.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
To address the issue, refer to the Troubleshooting section.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
We fixed the issue in Automation Suite 2023.10.10.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Grafana dashboard error
Erratum - added June 10, 2025: In multi-node (HA) setups, Grafana runs with two replicas, but there is no common data source between the replicas, causing issues in user session management. Errors like Dashboard not found and Invalid dashboard UID in the request appear in the Grafana dashboard.
As a workaround, since Grafana is not a critical application, you can reduce the replica count to one by performing the following steps:
  1. Modify the helm parameter for the fabric-installer application. This automatically triggers the sync operation for fabric-installer application.
    kubectl patch   application fabric-installer -n argocd    --type='json'  -p='[{"op": "add", "path": "/spec/source/helm/parameters/-", "value": {"name": "global.rancherMonitoring.grafana.replicas", "value": "1"}}]'
  2. Sync the rancher-monitoring application from ArgoCD UI.
We have fixed this issue in Automation Suite 2023.10.7.
uipathctl health check command
Erratum - added May 21, 2025: For offline Automation Suite installations using the external docker registry, the uipathctl health check command does not work due to a known issue. This issue has been fixed in Automation Suite 2023.10.6.
As a workaround, you can download the uipathctl binary from Automation Suite 2023.10.6 and use it to run the uipathctl health check command.
Kubernetes upgrade failure
Erratum - added April 15, 2025: An issue causes the Kubernetes upgrade to fail due to a missing certificate-injector-webhook in deployment.apps. To address the issue, you must run the following command:
kubectl delete configmap -n uipath-infra certificate-injector-webhook-configmap --ignore-not-found
We fixed the issue in Automation Suite 2023.10.9.
Document Understanding deployment issue post-upgrade
Erratum - added April 15, 2025: An issue prevents you from importing files into your DM session in AI Center after upgrading to Automation Suite 2023.10.x. This issue occurs due to the du-digitizer-worker deployment from the old Automation Suite version not being fully cleaned up after the upgrade. Starting with Automation Suite 2023.10.0, the deployment was renamed to du-digitizer-worker-deployment.
To address the issue, you must navigate to the ArgoCD UI and from the documentunderstanding application, manually delete the old du-digitizer-worker deployment. After deletion, re-sync the documentunderstanding application.
We fixed the issue in Automation Suite 2023.10.8.
Incomplete Docker registry cleanup process
Erratum - added April 15, 2025: An issue prevents the registry cleanup command from effectively clearing the unused Docker images from all registry pods. To address the issue, refer to the Troubleshooting section.
Upgrade fails due to MongoDB to SQL Server migration
Erratum - added April 15, 2025: We have identified an issue impacting the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2023.10.0 or later. Due to a faulty migration from MongoDB to SQL Server, the upgrade operation fails if you have Apps enabled and use Kerberos authentication for the SQL Server database.
The recommended solution is to upgrade to Automation Suite 2023.10.9.
Kube-proxy health check not working
Erratum - added April 15, 2025: The node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, is not working for specific nodes such as GPU, task-mining, or as-robot. We have fixed this issue in Automation Suite 2023.10.9.
Kerberos tickets do not automatically renew
Erratum - added April 15, 2025: Kerberos tickets fail to automatically renew after cluster restoration, requiring manual sync of the Windows Auth app.
This issue is fixed in Automation Suite 2023.10.9.
AI Center storage migration failure
Erratum - added February 13, 2025: An issue prevents uipathctl from correctly setting executeMigration to true during the migration process from Ceph in-cluster storage to external object storage in AI Center.
To fix this issue, you must manually set executeMigration to true in ArgoCD for AI Center and then proceed with a resync, ensuring to prune. This issue is fixed in Automation Suite 2023.10.8.
ML skill deployment failure due to token expiry
Erratum - added February 13, 2025: Due to a containerd issue, the deployment of ML skills fails as a token expires before larger image downloads can be completed, especially under conditions of slower network connectivity.
To address this isssue, see the Troubleshooting section.
Email alerts configuration failure post upgrade
Erratum - added February 13, 2025: An issue affects the functionality of email alerts configuration and the setup of multiple receivers after upgrading from Automation Suite 2022.10. To address this issue, see Troubleshooting.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.4Automation Ops 2023.10.4AI Center 2023.10.4Action Center 2023.10.4
Task Mining 2023.10.4AI Computer Vision 2023.10.4Insights 2023.10.4Apps 2023.10.4
Process Mining 2023.10.4Document Understanding 2023.10.4Orchestrator 2023.10.5
Test Manager 2023.10.4
Data Service 2023.10.4
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.28.7
ArgoCD2.10.9
logging-operator4.6.0
logging-operator-logging4.6.0
gatekeeper3.16.0
rook-ceph1.9.4
prometheus-pushgateway2.12.0
cert-manager1.14.5
rancher-istio102.5.0-up1.19.6
rancher-logging103.0.0-up3.17.10
rancher-logging-crd103.0.0-up3.17.10
rancher-monitoring-crd103.1.0-up45.31.1
rancher-gatekeeper-crd103.1.0-up3.13.0
rancher-gatekeeper103.1.0-up3.13.0
rancher-monitoring103.1.0-up45.31.1
longhorn1.5.5
longhorn-crd1.1.100
reloader1.0.95
csi-driver-smb1.14.0
velero6.2.0
redis-operator7.4.2-12
redis-cluster7.4.2-129
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
