  • Automation Suite on Linux Release Notes
    • 2023.10.0
    • 2023.10.1
    • 2023.10.5
    • 2023.10.6
    • 2023.10.8
    • 2023.10.9
    • 2023.10.10
    • 2023.10.11
  • Automation Suite on EKS/AKS Release Notes
Automation Suite release notes
Last updated Mar 26, 2026
2023.10.9
Release date: April 15, 2025
Support for new RHEL version
We have expanded our OS support to include RHEL 9.6. For details on the supported RHEL versions, see Compatibility Matrix.
Release date: September 24, 2025
Additional custom CA certificate support
Previously, you could update only ArgoCD CA certificates via the ./bin/uipathctl config argocd ca-certificates update --cacert [PATH] command. For details, refer to the Managing the external OCI-compliant registry certificate section.
Now, you can add any additional custom CA certificate for Docker registries in online environments during initial install time. You can do this by providing the registry_ca_cert key with the external CA certificate path in the cluster_config.json file. For details, refer to the External OCI-compliant registry configuration page.
PostgreSQL for Process Mining Airflow database
For Process Mining on Automation Suite 2023.10.9, you can now choose to use PostgreSQL for the AutomationSuite_Airflow database. If you choose not to use PostgreSQL and keep using Microsoft SQLServer, Process Mining on Automation Suite 2023.10.9 will run with a legacy version of Airflow.
Refer to SQL Requirements for Process Mining for more information on how to set up a PostgreSQL AutomationSuite_Airflow metadatabase.
Important:
You are recommended to move to PostgreSQL for the Airflow database, as PostgreSQL runs with the latest versions of Apache Airflow. Latest versions of Apache Airflow have various functionality, performance, and security fixes that older versions lack.
Removed Dapr dependency for Process Mining
Starting with Automation Suite 2023.10.9, Process Mining will no longer have a dependency on Dapr.
Task-Mining, however, will still continue to have a dependency on Dapr.
If you are installing Automation Suite where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will not be installed.
In case of an Automation Suite upgrade where Process Mining is enabled and Task Mining is not enabled, then the Dapr application will be automatically uninstalled.
Enhanced telemetry
Enhanced Automation Suite with a high-level summarized usage telemetry feature, provided guidance on viewing the generated XML file, and added telemetry sharing with UiPath Support via the Customer Portal.
Istio HSTS enabled by default
To enhance security, Istio HSTS is now enabled by default.
Optional Docker pull secret value
The registries.docker.pull_secret_value field, which needs to be provided in the cluster_config.json file, is now optional.
Bug fixes
  • Erratum - added April 15, 2025: An issue related to AI Center caused Microsoft SQL Server 2016 to throw the following exception: exception":"com.microsoft.sqlserver.jdbc.SQLServerException: 'OPTIMIZE_FOR_SEQUENTIAL_KEY' is not a recognized CREATE INDEX. We have fixed the issue.
  • An issue caused the service upgrade script to abruptly end with non-zero exit code when upgrading from lower versions to 2023.10.x. This issue occurred when one of the pre-upgrade script, namely scale-down-insights-looker-deployment.sh, failed in certain scenarios. This issue is now fixed.
  • Kerberos tickets failed to automatically renew after cluster restoration. This issue is now fixed, expired Kerberos tickets are now automatically detected and restored.
  • An issue was causing the node-monitor component, which monitors the node for issues such as checking kube-proxy health or if ip_forward is enabled, and cordons the node if issues arise, to not work for specific nodes such as GPU, task-mining, or as-robot. We have fixed the issue.
  • We have fixed an issue causing the side-by-side and the in-place upgrade of Automation Suite 2022.10 or earlier to Automation Suite 2023.10.0 or later to fail when Apps was enabled and you used Kerberos authentication for the SQL Server database.
  • Previously, the configuration of user authentication and SQL authentication for the Automation Suite cluster was interconnected. To use either of them, you had to set both kerberos_auth_config.enabled and kerberos_auth_config.enable_integrated_sql_auth parameters to true. Currently, we allow independent configuration of only user authentication by setting kerberos_auth_config.enabled to true and kerberos_auth_config.enable_integrated_sql_auth to false. Independent SQL authentication is still not supported.
  • An issue was preventing the registry cleanup command from effectively clearing the unused Docker images from all registry pods. We have fixed the issue.
  • An issue was preventing the installer from automatically creating and validating the Orchestrator database. The issue occurred even though the sql.create_db parameter was set to true in cluster_config.json. We have fixed the issue.
  • An issue was causing the Kubernetes upgrade to fail due to a missing certificate-injector-webhook in deployment.apps. We have fixed the issue.
Known issues
FIPS 140-2 support limitations
Erratum - added January 22, 2026: Insights is not supported on Automation Suite deployments that run on FIPS 140-2-enabled machines. To remain compliant with FIPS 140-2 requirements, you must disable Insights.
For details, refer to Security and compliance.
Kerberos keytab rotation does not trigger token regeneration
Erratum - added September 24, 2025: An issue causes Kerberos keytab rotation to not immediately regenerate authentication tokens, which may lead to temporary connectivity disruptions between services and the database.
To address the issue, you must manually trigger the Kerberos ticket renewal cronjob by running the following command:
kubectl delete job tgt-rotate-manual -n uipath --ignore-not-found ; kubectl create job tgt-rotate-manual --from=cronjob/kerberos-tgt-update -n uipath
We fixed the issue in Automation Suite 2023.10.11.
GPU enablement fails with external registries containing project names
Erratum - added September 24, 2025: An issue prevents GPU enablement after adding a GPU node when using external registries with project names (such as Harbor). The required pods do not start and display an ImagePullBackoff error.
If you are using an external registry with a project name, update the NVIDIA device plugin daemonset with the following command:
# Replace REGISTRY_WITH_PROJECT_NAME with the correct value (Eg. my.registry.io:443/myproject)
# Replcae TAG with the correct value. You can get this from the <installer_directory>/versions/docker-images.json file (Eg. v0.17.1)
kubectl set image daemonset/nvidia-device-plugin-daemonset \
  -n kube-system \
  nvidia-device-plugin-ctr=<REGISTRY_WITH_PROJECT_NAME>/k8s-device-plugin:<TAG>
  -n kube-system \
Orchestrator does not start when using user-assigned managed identity
Erratum - added September 24, 2025: An issue prevents the storage.useClientID parameter from being set when you select a user-assigned managed identity for object storage. As a result, Orchestrator cannot start in environments where access is restricted to user-assigned managed identities.
To address the issue, you must manually set the parameter in ArgoCD, as follows:
  1. In the ArgoCD Orchestrator application, go to Details > Parameters.
  2. In the values text box, set storage.isExternal : true and save.
Thanos compactor stops on corrupted blocks
Erratum - added September 24, 2025: An issue causes the Thanos compactor to stop compacting metrics when it encounters corrupted blocks in the object store. This prevents compaction and leads to increased storage usage.
To address the issue, refer to the Troubleshooting section.
Task Mining Kerberos initialization failure
Erratum - added June 26, 2025: An issue causes the Task Mining service to fail to initialize in Kerberos environments. This issue occurs when the kerberos-discoverygroup-user-keytab secret is missing or when the discoverygroup app is not included in the enabledApps parameter of the IntegratedAuth app.
We fixed the issue in Automation Suite 2023.10.10.
Agent node addition failure in offline environments
Erratum - added June 26, 2025: An issue causes the addition process of agent nodes in offline environments to fail. Agent node additions require the temporary registry to be running. To address the issue, you must re-enable the temporary registry to successfully join the agent node.
Installation fails due to CA certificates with large policy OIDs
Erratum - added June 26, 2025: An issue causes the Automation Suite installation to fail when using Certificate Authority (CA) certificates that include a CertificatePolicies section with policy OID values exceeding 4 bytes. This issue prevents Automation Suite from recognizing these CA certificates, interrupting the installation process.
To address the issue, you must either ensure that the policy OID values within the CertificatePolicies section do not exceed 4 bytes, or avoid using CA generators that add the CertificatePolicies section to the certificates.
RKE2 custom configuration overwrite during upgrade
Erratum - added June 26, 2025: An issue causes the custom changes made to the RKE2 configuration file (/etc/rancher/rke2/config.yaml) to be overwritten during upgrades.
To address the issue, you must reapply your custom changes to the configuration file after each upgrade.
Licensing SQL connection error
Erratum - added June 26, 2025: Licensing SQL connection errors occur when the Data Source property specified both a named instance and a port.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Product versions
To find out what has changed on each Automation Suite product, visit the following links.
If the product is greyed out, this new Automation Suite version does not bring any changes to it.
DISCOVERBUILDMANAGEENGAGE
Automation Hub 2023.10.9Automation Ops 2023.10.9AI Center 2023.10.9Action Center 2023.10.9
Task Mining 2023.10.9AI Computer Vision 2023.10.9Insights 2023.10.9Apps 2023.10.9
Process Mining 2023.10.9Document Understanding 2023.10.9Orchestrator 2023.10.10
Test Manager 2023.10.9
Data Service 2023.10.9
Internal third-party component versions
This Automation Suite release bundles the following internal components:
ComponentVersion
RKE21.31.4+rke2r1
ArgoCDv2.14.4
Grafana11.1.0
ceph19.2.0
rook-ceph1.16.1
prometheus-pushgatewayv3.0.0
cert-managerv1.17.1
rancher-istio105.4.0-up1.23.2
rancher-monitoring-crd105.1.3-up61.3.2
rancher-gatekeeper104.0.1-up3.13.0
rancher-monitoring105.1.3-up61.3.2
longhorn1.7.3
longhorn-crd1.1.100
reloaderv2.0.0
kube-logging/logging-operator5.2.0
kube-logging/config-reloaderv0.0.7
velero1.15.2
csi-driver-smbv1.16.0
redis-operatorv7.8.4-9
redis-clusterv7.8.4-95.focal
oauth2-proxyv7.8.1
Migration tool version
The migration tool version you need depends on the standalone products you plan to migrate and the targeted Automation Suite version. For more details, see Migration compatibility matrix.
For instructions on migrating a standalone product to the current version of Automation Suite, see Full migration.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
