- Automation Suite on Linux Release Notes
- Automation Suite on EKS/AKS Release Notes
2023.10.2+patch4
2023.10.2 Patch 4 release notes for Automation Suite on EKS/AKS.
Release date: May 21, 2025
About this patch
This release applies a patch to Automation Suite 2023.10.2. The patch addresses a cache validation issue that was preventing you from immediately receiving permissions when granted the App Creator role in Apps. With this patch, the issue has been fixed.
This fix will also be included in all future releases starting with Automation Suite 2023.10.9.
How to apply the patch
To apply this patch, follow the instructions in Applying a patch.
Deprecation timeline
We recommend that you regularly check the deprecation timeline for any updates regarding features that will be deprecated and removed.
Bundling details
Internal third-party component versions
For the Kubernetes versions that each Automation Suite version supports, see Kubernetes compatibility.
This Automation Suite release bundles the following internal components:
| Component | Version |
| Istio | 1.20.0 |
| ArgoCD | v2.7.7 |
| Prometheus | v2.42.0 |
| Grafana | 10.2.3 |
| Fluentd & Fluent-bit | logging-operator: 4.2.1 logging-operator-logging: 4.2.1 |
| Gatekeeper | 3.12.0 |
| Cert-Manager | v1.12.3 |
| Velero | 3.1.6 |
