uipathctl 参考指南
uipathctl manifest apply
在 Automation Suite 中对集群应用配置,并将状态提升到所需状态。
描述​
加载在 PATH 中找到的配置,并将其应用于集群。
该命令在集群的当前状态和所需状态之间执行差异,并将更改应用于集群。
当存在 --override 标志时,列表将覆盖在输入文件中找到的选择。 该标志与 --only 标志互斥。 当输入文件中存在 exclude_components 键时,列表中找到的组件将从已安装的组件中排除。 它的优先级高于所有其他标志,并且与其中任何标志都不互斥。
uipathctl manifest apply PATH [flags]
示例​
# Apply the configuration found in input.json, using the versions found in versions.json
uipathctl manifest apply input.json/cluster_config.json --versions versions.json
# Apply the configuration and specify the kubeconfig file to use
uipathctl manifest apply input.json/cluster_config.json --kubeconfig cluster.kubeconfig --versions versions.json
# Simulate the apply command and print on stdout the result of the operation
uipathctl manifest apply --dry-run input.json/cluster_config.json --versions versions.json
# Apply the configuration but skip the components installed directly by helm
uipathctl manifest apply --skip-helm input.json/cluster_config.json --versions versions.json
# Apply the configuration overriding the initial list of components
uipathctl manifest apply --override automation_hub,orchestrator --versions versions.json
选项​
      --component-timeout duration   timeout for individual components to be ready (default 15m0s)
      --continue-on-error            if true, continue applying the manifest even if an error occurs
      --dry-run                      if true, just print the result of the command, without applying it
      --fail-on-version              if true, fail if the version of the component is not found in the versions file
  -h, --help                         help for apply
      --no-wait                      if true, return immediately after the ArgoCD applications are created
      --only strings                 optional exclusive list of components to apply, doesn't touch the dependent components
      --override strings             optional list to override the components enabled in input.json file
      --skip-helm                    if true, skip components installed directly by helm
      --skip-oss-prereq              if true, skip OSS components prerequisites checks
      --versions string              path to versions file
从父命令继承的选项​
  • 描述​
  • 示例​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
