uipathctl 参考指南
uipathctl snapshot backup enable
在 Automation Suite 中启用带有计划的定期快照备份。
描述​
启用集群的定期快照备份。
uipathctl snapshot backup enable [flags]
选项​
  -h, --help               help for enable
  -p, --prefix string      This will prefix the names of all the snapshot backups with the given string.
                       This is only used if you wish to enable schedule backup.
                     The default value is snapshot
                        (default "snapshot")
  -r, --retention string   Retention policy in duration format Hh:Mm:Ss, for e.g 8h5m1s.
                       Default value of 168h.
                        (default "168h")
      --schedule string    Unix cron expression for schedule
                       this is only required if you wish to enable schedule backup.
                     Default value "*/45 * * * *" denotes every 45th minutes backup is triggered.
                        (default "*/45 * * * *")
                        (default "168h")
从父命令继承的选项​
  • 描述​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
