uipathctl 参考指南
uipathctl config add-host-admin
在 Automation Suite 中添加具有指定凭据的主机管理员。
描述​
添加主机管理员并指定其凭据。
该命令默认为 kubeconfig 文件中的当前上下文。 如果设置了 --kubeconfig 标志,则它使用该标志指定的 kubeconfig 文件。
uipathctl config add-host-admin [flags]
示例​
# Add host admin with the provided username and password in cluster
uipathctl config add-host-admin --username newadmin --password password
# Add host admin with the provided username, password and email in cluster
uipathctl config add-host-admin --username newadmin --email email --password password
# Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
uipathctl config add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
选项​
  -e, --email string       host admin email
  -h, --help               help for add-host-admin
      --namespace string   The namespace where UiPath Automation Suite is deployed (default "uipath")
  -p, --password string    host admin password
  -u, --username string    host admin username
从父命令继承的选项​
  • 描述​
  • 示例​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
