uipathctl 参考指南
uipathctl 配置 Orchestrator 上传
将文件、NLog 扩展程序或安全存储插件上传到存储。
描述​
将文件、nlog 扩展程序或安全存储插件上传到存储空间
uipathctl config orchestrator upload [flags]
示例​
# Upload files to storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory
# Upload nlog extensions to storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory
# Upload secure store plugins to storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory
# Upload files to external storage
uipathctl config orchestrator upload --storage-directory /path/to/storage/directory --is-external-storage
# Upload nlog extensions to external storage
uipathctl config orchestrator upload --nlog-extensions-directory /path/to/nlog/extensions/directory --is-external-storage
# Upload secure store plugins to external storage
uipathctl config orchestrator upload --securestore-plugins-directory /path/to/securestore/plugins/directory --is-external-storage
选项​
  -h, --help                                   help for upload
      --is-external-storage                    flag whether the storage is external
      --namespace string                       The namespace where UiPath Automation Suite is deployed (default "uipath")
      --nlog-extensions-directory string       location of the nlog extensions on the local disk
      --securestore-plugins-directory string   location of the securestore plugins on the local disk
      --storage-directory string               location of the storage directory on the local disk
从父命令继承的选项​
  • 描述​
  • 示例​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
