uipathctl 参考指南
uipathctl 运行状况
用于打印组件运行状况的运行状况检查子命令。
描述​
打印组件的运行状况。
uipathctl health [flags]
选项​
      --excluded strings   components to be excluded from execution, defaults to none
  -h, --help               help for health
      --included strings   components to be included in the execution, defaults to all
  -o, --output output      output format. one of [json,yaml,text,junit] (default text)
从父命令继承的选项​
  • 描述​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
