uipathctl 参考指南
uipathctl registry seed
Automation Suite 中的种子 Docker 注册表。
描述​
种子 Docker 注册表。
uipathctl registry seed [flags]
选项​
      --dest-password string     Destination registry password
      --dest-registry strings    List of destination registry
                             Note: All registry needs to have same username password
      --dest-username string     Destination registry username
  -h, --help                     help for seed
      --num-worker int           Number of workers to seed images in parallel (default 3)
      --source-password string   Source registry password
      --source-registry string   Source registry
      --source-username string   Source registry username
      --tag-file string          Path to file containing list of image/helm-chart tags
      --tar-file string          Path to the tar file containing images
从父命令继承的选项​
  • 描述​
  • 选项​
  • 从父命令继承的选项​
此页面有帮助吗?
连接
需要帮助? 支持
想要了解详细内容? UiPath Academy
有问题? UiPath 论坛
保持更新
