maestro
Maestro user guide
- Introduction
- Getting started
- Building with Maestro BPMN
- Understanding Maestro BPMN modeling
- Opening the modeling canvas
- Modeling your process
- Aligning and connecting BPMN elements
- Patterns library
- Autopilot for Maestro (Preview)
- Process Repository
- Implementing a simple BPMN process
- Implementing a complex BPMN process
- Build a Maestro BPMN with a coding agent (preview)
- Debugging
- Simulating
- Evaluations (Preview)
- Common implementation scenarios
- Building with Maestro Case
- Introduction to Maestro Case
- Maestro BPMN vs. Maestro Case: when to use case management
- The Maestro Case lifecycle: from event trigger to app experience
- Build your first case with Maestro Case
- Build a Maestro Case with a coding agent (preview)
- Defining case keys (system vs. external)
- Establishing task I/O and write-back contracts
- Exit rules and early stage termination
- Modeling primary and secondary stages
- Triggering a case from Data Fabric
- Implementing stage-level personas and permissions
- Setting SLAs and automated escalation rules
- Configuring a rework loop (re-entry)
- Configuring and testing the Case Manager Agent (preview)
- Case Manager input and output contract
- Maestro Case component dictionary
- Building with Maestro Flow
- Maestro Automate
- Integrations
- Operating
- Monitoring
- Optimizing
- Reference information
Node reference
Reference for the nodes available in Flow, including built-in nodes and connector nodes.
This section is a reference for the nodes you place on the Flow canvas. It groups the built-in nodes that ship with Flow and the connector nodes that integrate with external systems.
The reference entries describe what each node does, its inputs and outputs, and its configuration.
These are the node reference categories:
