maestro
Maestro user guide
- Introduction
- Getting started
- Building with Maestro BPMN
- Understanding Maestro BPMN modeling
- Opening the modeling canvas
- Modeling your process
- Aligning and connecting BPMN elements
- Patterns library
- Autopilot for Maestro (Preview)
- Process Repository
- Implementing a simple BPMN process
- Implementing a complex BPMN process
- Debugging
- Simulating
- Evaluations (Preview)
- Common implementation scenarios
- Building with Maestro Case
- Introduction to Maestro Case
- Maestro BPMN vs. Maestro Case: when to use case management
- The Maestro Case lifecycle: from event trigger to app experience
- Build your first case with Maestro Case
- Build a Maestro Case with a coding agent (preview)
- Defining case keys (system vs. external)
- Establishing task I/O and write-back contracts
- Exit rules and early stage termination
- Modeling primary and secondary stages
- Triggering a case from Data Fabric
- Implementing stage-level personas and permissions
- Setting SLAs and automated escalation rules
- Configuring a rework loop (re-entry)
- Configuring and testing the Case Manager Agent (preview)
- Case Manager input and output contract
- Maestro Case component dictionary
- Building with Maestro Flow
- Maestro Automate
- Integrations
- Operating
- Monitoring
- Optimizing
- Reference information
Flow and routing
Build linear and decision-based process flows in Maestro using sequence flow, exclusive gateways, and routing patterns for approval and compliance workflows.
Straight-through flow (step-by-step)
Use when
- You want a simple, linear process.
- Each task must finish before the next begins.
- There is at most one decision near the end.
Pattern in simple words
- Start.
- User task: Collect compliance forms.
- Service task: Validate information.
- Exclusive gateway: Complete?
- If Yes: User task Approve supplier. End Approved.
- If No: User task Request resubmission. End Needs update.
Note:
Keep the main path short. Defer exceptions to separate patterns.
Other scenarios
- Finance: Process payroll batch. Approve. Send to payment.
- Insurance: Register claim. Verify data. Route to adjuster.
- Healthcare: Intake form review. Approve patient registration.
- Manufacturing: Material intake. Check specs. Approve supplier.
- Retail: Product listing. Check completeness. Publish or revise.
Either‑or decision with default path (exclusive)
Use when
- A single decision is mandatory.
- One branch should always run, even when conditions are not met.
- You want to prevent unhandled cases.
- Start.
- Service task: Check inventory.
- Exclusive gateway: In stock?
- If Yes: Service task Ship order. End Shipped.
- Default: Service task Create backorder. End Backordered.
Note:
Mark the default path on the gateway.
Other scenarios
- Finance: Check budget. Approve or hold request.
- Healthcare: Prescription renewal. Dispense or contact doctor.
- Retail: Confirm stock. Fulfill or backorder.
- Public sector: Verify data. Approve or return for correction.
- Telecom: Check coverage. Activate or escalate.
Do tasks at the same time, then continue (parallel)
Use when
- Several steps can run concurrently without dependencies.
- All branches must complete before moving forward.
Start.
Parallel gateway: split.
- Service task: Blood tests.
- Service task: Imaging.
- User task: Consent verification.
Parallel gateway: join.
User task: Review results.
End Ready for procedure.
Note:Use a matching parallel join to synchronize.
Other scenarios
- Finance: Tax filing, payments, and confirmations run together.
- Insurance: Collect claim evidence, police report, and adjuster notes in parallel.
- Manufacturing: Run QA, design validation, and material checks concurrently.
- Retail: Update pricing, marketing, and stock lists together.
- Public sector: Conduct budget, legal, and policy reviews in parallel.
Run any needed subset, then merge (inclusive)
Use when
- One, several, or none of the branches may be required.
- The process must merge cleanly regardless of which branches ran.
Start.
Inclusive gateway: split.
- User task: Request photos.
- User task: Request repair estimate.
- User task: Request police report.
Inclusive gateway: merge.
User task: Assess claim.
End Decision made.
Note:Use inclusive merge to handle variable combinations safely.
Other scenarios
- Finance: Optional compliance or fraud checks.
- Healthcare: Trigger labs and imaging only when required.
- Retail: Gather optional marketing or packaging assets.
- Public sector: Collect specific applicant forms when applicable.
- Manufacturing: Run optional quality audits.
First event wins (event‑based gateway)
Use when
- The process waits for either a reply or a deadline.
- You need “whichever happens first” behavior.
- Start.
- Send task: Send approval request.
- Event‑based gateway: wait for one of the following.
- Message event: Approval received. Then user task Process request. End Approved.
- Timer event: Seven days elapsed. Then user task Escalate decision. End Escalated
Note:Keep exactly one message and one timer attached to the gateway.
Other scenarios
- Finance: Loan documents received versus deadline leads to auto‑decline.
- Healthcare: Lab results received versus escalate to specialist.
- Manufacturing: Engineering sign‑off versus escalate to production.
- Retail: Supplier quote versus alternate sourcing.
- Public sector: Public comment versus policy vote.
- Straight-through flow (step-by-step)
- Use when
- Pattern in simple words
- Other scenarios
- Either‑or decision with default path (exclusive)
- Use when
- Other scenarios
- Do tasks at the same time, then continue (parallel)
- Use when
- Run any needed subset, then merge (inclusive)
- Use when
- First event wins (event‑based gateway)
- Use when
- Other scenarios
