- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Monitor license allocation in Automation Suite from the Home page and the Licenses page, viewing purchased and assigned counts by user, robot, and consumable license type.
From the Home page
The homepage displays license allocation at the organization level.
Check the License Allocation section to view the number of allocated licenses out of the total number of purchased licenses in your organization. Switch between the available tabs to change the displayed license information per license type.
From the Licenses page
You can view license allocation details from the platform-level Licenses page, for either the entire organization, or just one tenant:
- For the entire organization, access Admin > organization > Licenses.
- For a particular tenant, access Admin > tenant > Licenses.
The Licenses page displays the number of all purchased licenses in your organization. Switch between these tabs to view license information per license type:
- Users - displays user licenses.
- Robots & services - displays service capacity items, such as runtimes, Data Fabric units, and Computer Vision licenses.
- Consumables - displays licensed consumption units, such as AI Units, Robot Units, and Integration Service API calls.
If a license type is not displayed, it means there are 0 licenses of that type purchased for your organization.
The Users and the Robots & services tabs
Hover over the progress bar on the Users and Robots & services tabs to view the number of allocated licenses out of the total number of purchased licenses in your organization.
The Consumables tab
Select the cards on the Consumables tab to view details about how your organization's or tenant's service consumption units are used per month or per year.
The following table describes what you can expect to notice depending on the level:
| Level | Information | Further details |
| ORGANIZATION | The total number of units in the account |
| The total number of consumed units vs. the total number of available units | N/A | |
| Usage details for AI units 1 |
| Usage details for robot units |
| Usage details for Integration Service API calls |
| Usage details for agent units |
| TENANT | The total number of units allocated to the selected tenant |
1 You can view a detailed breakdown of AI units consumption across various products, projects, and hardware by checking out the AI units consumption overview Insights dashboard.
