Automation Suite admin guide
Last updated May 30, 2025
Monitoring license allocation
From the Home page
The homepage displays license allocation at the organization level.
Check the License Allocation section to view the number of allocated licenses out of the total number of purchased licenses in your organization. Switch between the available tabs to change the displayed license information per license type.
From the Licenses page
You can view license allocation details from the platform-level Licenses page, for either the entire organization, or just one tenant:
  • For the entire organization, access Admin > organization > Licenses.
  • For a particular tenant, access Admin > tenant > Licenses.
The Licenses page displays the number of all purchased licenses in your organization. Switch between these tabs to view license information per license type:
  • Users - displays user licenses.
  • Robots & services - displays service capacity items, such as runtimes, Data Service units, and Computer Vision licenses.
  • Consumables - displays licensed consumption units, such as AI Units, Robot Units, and Integration Service API calls.
If a license type is not displayed, it means there are 0 licenses of that type purchased for your organization.
'View licenses' image
The Users and the Robots & services tabs
Hover over the progress bar on the Users and Robots & services tabs to view the number of allocated licenses out of the total number of purchased licenses in your organization.
The Consumables tab
Select the cards on the Consumables tab to view details about how your organization's or tenant's service consumption units are used per month or per year.
The following table describes what you can expect to notice depending on the level:
Level
Information
Further details
ORGANIZATION
The total number of units in the account
  • Their start date
  • Their expiration date
  • If the units reset monthly, their reset date
The total number of consumed units vs. the total number of available units
N/A
Usage details for AI units1
  • The total number of consumed units, counted from the start date, and split per service which registers the consumption of such units.
  • The number of units consumed each month, counted over the past 12 months, and split per service which registers the consumption of such units.
Usage details for robot units
  • The number of units consumed each month, counted over the past 12 months, and split between Serverless and VM robots.
  • The number of units consumed during the current month by Serverless robots.
Usage details for Integration Service API calls
The number of calls consumed each month, counted over the past 12 months, and split based on their type: API calls bundled with license or API calls purchased as a dedicated bundle.
TENANT
The total number of units allocated to the selected tenant
  • Their start date
N/A
1 You can view a detailed breakdown of AI units consumption across various products, projects, and hardware by checking out the AI units consumption overview Insights dashboard.
The Consumables tabThe Consumables tab with all sections collapsed
AI Units usage expandedThe Consumables tab with the AI Units usage section expanded
