- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
Important:
The licensing information on this page applies to you if you are on Unified Pricing. If you are on Flex, refer to Flex licensing plan framework.
You can use Automation Suite with a licensing plan to match your automation needs and budget.
Plan overview
The following sections provide a high-level description of the licensing plans available in the Unified Pricing model.
Standard
The Standard plan provides the following benefits:
- It helps you discover opportunities for continuous process optimization.
- It provides core governance, security, enterprise scale capabilities to enable IT to manage automation.
Enterprise
The Enterprise plan provides the following benefits:
- It provides industry-leading governance, security, enterprise scale capabilities.
Plan breakdown
The following table describes the benefits of each licensing plan at platform level. For information on product-specific benefits, refer to each product guide.
| Plan perks | Standard | Enterprise |
| Max. tenants | Unlimited | Unlimited |
| Data residency | Customer choice, single region for orgs and tenants | Customer choice per tenant |
| Access to UiPath Support | UiPath Bronze Support | UiPath Bronze Support |
| Standard audit | Yes | Yes |
| Advanced audit (five year data retention policy for audit logs) | No | Yes |
| Basic user management | Yes | Yes |
| Check access | Yes | Yes |
| Custom roles | Yes | Yes |
| Single Sign-On and provisioning | Yes | Yes |
| Mail settings | Yes | Yes |
| External credential store | No | Yes |
| Customer Managed Keys (CMK) | No | Yes |
| Bring your own LLM subscription | No | Yes |
| Elastic Robot Orchestration | No | Yes |
| Real-time monitoring and alerts in Insights | Yes | Yes |
| USER LICENSES 1 | ||
| Basic User | As purchased | As purchased |
| Plus User | As purchased | As purchased |
| Pro User | As purchased | As purchased |
| ROBOT LICENSES | ||
| Automation Test Robot | As purchased | As purchased |
| Unattended Robot | As purchased | As purchased |
| CONSUMPTION UNITS | ||
| Platform Units | As purchased | As purchased |
Important:
1 In Unified Pricing, you must enable User License Management to view and manage user licenses.
