Automation Suite admin guide
Configuring SSO: Microsoft Entra ID
You can use Microsoft Entra ID as your identity provider.
  1. Create a Microsoft Entra ID App Registration:
    Note:
    The following steps are a broad description of a sample configuration. For more detailed instructions, refer to the Microsoft documentation for configuring Microsoft Entra ID as an authentication provider.
    1. Log in to the Azure portal as an administrator, go to App Registrations , and select New Registration.
    2. In the Register an application page, fill in the Name field with a name for Automation Suite.
    3. In the Supported account types section, select Accounts in this organizational directory only.
    4. Set the Redirect URI by selecting Web from the drop-down list and filling in the Identity base URL, plus the suffix /azure-signin-oidc. For example, https://{yourDomain}/{organizationName}/identity_/azure-signin-oidc.
    5. At the bottom, select the ID tokens checkbox.
    6. Select Register to register Automation Suite.
    7. Save the Application (Client) ID for later.
  2. Configure Microsoft Entra ID SSO:
    1. Log in to the host portal as a system administrator.
    2. Make sure that Host is selected at the top of the left pane and then select Security.
    3. Under Microsoft Entra ID SSO, select Configure.
      • Select the Force automatic login using this provider checkbox if you want to only allow login with Microsoft Entra ID accounts.
      • In the Display Name field, type the text you want to show under this login option on the Login page.
      • In the Client ID field, paste the value of the Application (Client) ID obtained from the Azure portal.
      • (Optional) In the Client Secret field, paste the value obtained from the Azure portal.
      • Set the Authority parameter to one of the following values:
        • https://login.microsoftonline.com/<tenant>, where <tenant> is the tenant ID of the Microsoft Entra ID tenant or a domain associated with this Microsoft Entra ID tenant. Used only to sign in users of a specific organization.
        • https://login.microsoftonline.com/common. Used to sign in users with work and school accounts or personal Microsoft accounts.
      • (Optional) In the Logout URL, paste the value obtained from the Azure portal.
    4. Select Save to save the configuration and return to the previous page.
    5. Select the toggle to the left of Microsoft Entra ID SSO to enable the integration.
    6. Restart the identity-service-api-* pod. This is required after making any changes to external providers.
      1. Connect to your Automation Suite cluster.
      2. Run the following command: kubectl -n uipath rollout restart deployment identity-service-api
  3. Allow Microsoft Entra ID SSO for the organization:
Now that Automation Suite is integrated with Microsoft Entra ID Sign-In, user accounts that have a valid Microsoft Entra ID email address can use the Microsoft Entra ID SSO option on the Login page to sign in to Automation Suite.
Each organization administrator must do this for their organization if they want to allow login with Microsoft Entra ID SSO.
Figure 1. Azure AD sign in option
  1. Log in to Automation Suite as an organization administrator.
  2. Add user accounts, each with a valid Microsoft Entra ID email address.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
