Automation Suite admin guide
Configuring fine-grained access for confidential apps
As an administrator, you can configure fine-grained tenant or folder permissions for confidential apps, by assigning them to folders or tenants in Orchestrator. An external app gets the permissions required to perform particular operations in a folder or tenant through one or more roles.
An app gets the union of all organization and tenant scopes defined for it.
For example, Finance and HR are the two tenants in your organization. Your external app has the OR.Machines.Read scope at the organization level, and View permissions on Folders in the Finance tenant, and nothing defined for the HR tenant in Orchestrator. The following table offers an overview of your app's scope and what it can access:
TenantScope
HROR.Machines.Read
FinanceOR.Machines.Read OR.Folders.Read
Note:
External apps need to be assigned directly to a specific tenant and folder, instead of using group assignments.
Note:
When retrieving user roles through APIs using external application (token-based) authentication, only explicitly assigned roles are returned. Roles inherited through group membership are not included, as token-based authentication does not carry full user context such as group memberships. To retrieve complete role information including inherited roles, use user-based authentication (authorization code flow) instead.
Adding external apps to a tenant
To grant access to a tenant for an external app or a group of external apps, follow these steps in Orchestrator:
  1. Go to Tenant > Manage Access. The Manage Access page is displayed.
  2. Select Assign roles > External app. The Assign roles to an external app window is displayed.
  3. In the Search for an external app drop-down, search for the object you want to add.
  4. Under Roles, select the role(s) for this object.
  5. Select Assign.
Assigning external apps to a folder
To grant access to a folder for an external app or a group of external apps, follow these steps in Orchestrator:
  1. Go to Tenant > Folders. The Folders page is displayed.
  2. From the Folders page, in the Manage Folders pane, select the folder you want to manage. The folder and its contents are displayed on the right-hand dashboard.
  3. Select Assign accounts/group/external app. The Assign account/group/external app window is displayed.
  4. In the Account, group, or external app drop-down, search for the object you want to add.
  5. Under The Roles for the account/group, select the role(s) for this object.
  6. Select Assign. The selected object is now in the folder and can access it according to its role.
Removing Assignments
Removing external apps from a tenant
To remove tenant access for an external app or a group of external apps, follow these steps in Orchestrator:
  2. Select More Actions > Remove for the object you want to remove from the tenant and any other folders where it's been explicitly assigned. A confirmation window is displayed.
  3. Select Yes to confirm. The removed app is removed from the tenant.
Unassigning external apps from a folder
To remove folder access for an external app or a group of external apps, follow these steps in Orchestrator:
  2. From the Folders page, in the Manage Folders pane, select the folder you want to manage. The folder and its external apps are displayed on the right-hand dashboard.
  3. Select More Actions > Unassign for the object you want to remove from the folder. A confirmation window is displayed.
  4. Select Yes to confirm. The object is unassigned from the folder.
Checking external apps assignments
To view all the assignments of an external app or external app group in a tenant, follow these steps in Orchestrator:
  1. Go to Tenant > Manage Access in the tenant where you want to check the app assignments. The Manage Access page is displayed.
  2. Select More Actions > Check roles and permissions for the object you want to check assignments for. The Check Roles window is displayed showing a list of all the roles for the object at the tenant and folder levels.
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
