- Getting started
- Host administration
- Organizations
- Tenants and services
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Automation Suite admin guide
You can manage and assign service-level roles from within each service as long as you have the appropriate permissions in the service.
For example, users with the Administrator role in Orchestrator can create and edit roles, and assign roles to existing accounts.
Direct provisioning
Assigning organization-level roles
Organization-level roles are predefined and cannot be changed.
Organization administrators can assign organization-level roles to individual accounts from Admin > Accounts and Groups by adding accounts to a default or custom group.
If you have linked your UiPath organization to a directory, such as Microsoft Entra ID, then it is possible to also assign organization-level roles to directory groups by adding them to groups, same as with accounts. This is not possible with local groups.
Managing service-level roles
You manage and assign service-level roles from within the services. You can assign roles to groups (recommended), or to accounts that have already been added.
For information and instructions, refer to the applicable documentation, as described in the following table:
| Service | Details |
| Orchestrator | Managed from Orchestrator. |
| Actions | Managed from Orchestrator.
| Processes | Managed from Orchestrator.
| Automation Hub | Managed from Automation Hub. For more information about which roles are required and instructions for assigning them, refer to Role description and matrix . |
| Automation Store | Managed from Automation Hub. For more information about which roles are required and instructions for assigning them, refer to Role description and matrix . |
| AI Center | Managed from Orchestrator. For information about the roles required to use AI Center, refer to AI Center access control . |
| Data Service | Managed from Data Service.
| Document Understanding™ | Managed from Document Understanding. For more information about which roles are required and instructions for assigning them, refer to Role-based access control . |
| Test Manager | Managed from Test Manager. For information and instructions, refer to User and group access management . |
Assigning roles to an account
If you want to control the access a certain account has in a service at a more granular level, but you do not want to add new roles to an entire group, you can explicitly add the account to the service and assign one or more service-level roles to it directly.
For information about the available roles and instructions, refer to the documentation for the target service, as previously described.
Auto-provisioning
Through auto-provisioning, any directory account can be set up with access and rights for using the UiPath platform directly from the external identity provider (IdP).
Auto-provisioning requires a one-time setup after you enable an integration with a third-party IdP: Microsoft Entra ID or other IdPs that are connected used SAML integration.
Manage access user interface based on scope
The Manage access user interface (UI) keeps a consistent appearance across all scopes.
The following table illustrates how the Manage access UI looks like for each scope:
| Scope | Manage access UI |
| Organization | |
| Tenant | |
| Service | |
| Project |
As an organization administrator, you can navigate to Manage access at organization level to assign tenant-level roles.
To view the role definition and the permissions granted, take the following steps:
- Navigate to Manage access.
- In the Roles tab, select the View button next to the role.
You can assign an organization-level role to a user, group, robot account, or external application. To assign a role, take the following steps:
- Navigate to Manage access, then
- in the Role assignments tab, search for the account you want to assign the role to and choose the appropriate role.
- Select Assign.
Assigning tenant-level roles
Tenant-level roles can be assigned at tenant level and can have granted permissions up to the service level.
Organization Administrators or other Tenant Administrators can view the Manage access screen.
While Organization Administrators can access manage the access in any tenant, Tenant Administrators can manage access only in the tenant they manage.
To view the tenant-level role definition and the permissions granted at tenant and individual service level, take the following steps:
You can assign a tenant-level role to a user, group, robot account, or external application. To assign the role, take the following steps:
- In the Role assignments tab, select Assign role.
- Search for the account you want to assign the role to and choose the appropriate role.
- Select Assign to confirm the assignment.
Tenant Administrator role visibility at service level
The Tenant Administrator role assignment is visible both at tenant and individual service level. At the service level, the Tenant Administrator role has the following properties:
- It is shown with a platform role label.
- It is immutable, implying that you cannot remove the assignment at the service level.
- In some services, such as Orchestrator, there is a link next to the role that redirects you to the Manage access page at platform level, where you can change the tenant-level role assignments.
Assigning and managing service-level roles
You can manage and assign service-level roles from within the services. You can assign roles to groups (recommended), or to accounts that have already been added.
| Service | Details |
| Managed from AutomationOps. For more information, refer to AutomationOps user roles . |
| Managed from Orchestrator. For more information, refer to Orchestrator permissions . |
| Managed from Data Fabric.
| Managed from Insights. For more information, refer to Granting permissions . |
| Managed from Process Mining. For more information, refer to User management in Process Mining . |
| Managed from Studio Web. For more information, refer to Managing access to Studio Web . |
| Managed using Automation Suite organization-level roles. For information about the rights that organization-level roles grant in Task Mining, refer to Managing access and roles in the Task Mining documentation. |
Assigning folder- or project-level roles
Depending on the service you use, you can assign:
- folder roles from Orchestrator.
- project roles from:
- Document Understanding
- Test Manager
- Task Mining
For more information, refer to the table in Assigning and managing service-level roles.
Exporting role assignments
To export role assignments, take the following steps:
- Navigate to Admin at organization level.
- Select Accounts & local groups.
- Select Download role assignments for the roles you want to export.
The following table describes the fields from the role assignments file.
| Field | Description |
| Id | The unique identifier of the role assignment. |
| RoleName | The role name as displayed in the interface. For example, Folder Administrator |
| RoleId | The unique identifier of the role. |
| RoleDescription | The role description, as displayed in the interface. For example, Folder Administrator For example, Folder Administrator |
| RoleType | The role type, as defined by the user or the system:
| RoleAssignmentType | The role assignment type when it was created, which can be one of the following two options:
| Scope | The scope is a specific level in the organizational hierarchy that serves as a boundary for certain actions, permissions, and objects. A scope can be one of the following hierarchical options, represented as IDs:
| ScopeWithDisplayNames | The scope is a specific level in the organizational hierarchy that serves as a boundary for certain actions, permissions, and objects. A scope can be one of the following hierarchical options:
| ServiceName | The name of the UiPath service that the role belongs to. |
| SecurityPrincipalId | The unique identifier for the identity of a user, group, etc. |
| SecurityPrincipalType | The identity type of a user, group, or robot. |
| SecurityPrincipalEmail | The email of the user. This field is blank in case the identity is not a user. |
| SecurityPrincipalDisplayName | The name of the identity. This field is blank in case of directory users. |
| InheritedFromGroupName | The group name from which the role assignment is inherited. |
| InheritedFromGroupId | Group identifier from which the role assignment is inherited. |
| TenantName | The name of the tenant where the assignment is made. This field is blank in case of organization-level assignments. |
| OrganizationName | The name of the organization where the assignment is made. |
| OrganizationId | The identifier of the organization where the assignment is made. |
| TenantId | The identifier of the tenant where the assignment is made. This field is blank in case of organization-level assignments. |
| CreatedBy | The unique identifier of the user who creates the assignment. |
| CreatedByDisplayName | The name of the user who creates the assignment. |
| CreatedOn | The timestamp when the role is assigned. |
| FolderName | The name of the folder associated with the assignment. |
| FolderKey | The unique identifier of the folder associated with the assignment. |
| ProjectId | The ID of the project (for example, Document Understanding or IXP) associated with the assignment. |
- Direct provisioning
- Assigning organization-level roles
- Managing service-level roles
- Assigning roles to an account
- Auto-provisioning
- Manage access user interface based on scope
- Assigning tenant-level roles
- Tenant Administrator role visibility at service level
- Assigning and managing service-level roles
- Assigning folder- or project-level roles
- Exporting role assignments
