- Getting started
- Host administration
- Organizations
- Tenants and services
- About tenants
- Managing tenants
- Managing services
- Managing tags
- Authentication and security
- Licensing
- Accounts and roles
- External applications
- Testing in your organization
- AI Trust Layer
- Notifications
- Logging
- Troubleshooting
Add, configure, and manage tenants in Automation Suite, including setting tenant name, color, environment type, and provisioning services.
For examples on how you can use tenants to create separation of resources within your organization, refer to Examples of platform modelling.
Adding tenants
To create a new tenant, take the following steps:
Navigate to Admin in the Automation Suite portal.
In the Tenants view, select the Plus icon. The Create new tenant process starts with three steps to follow.
On the General step, provide the following information:
- Enter a name for your tenant in the Name field.
You can enter up to 32 alphabetical or numeric characters, starting with a letter. No spaces or special characters are allowed.Important: You can change the tenant name later, but there are consequences. Refer to Changing the tenant name.
- (Optional) Select a color from the Color picker to identify your tenant in the header when operating within that tenant.
- Select a tenant type from the Environment type section.
Environment type is a categorization label for organizational purposes. It does not currently affect service behavior, feature availability, or update rollout. Select the type that matches your tenant's intended use (Production, Staging, or Development) for easier identification. You can choose from three types of environments:- Production tenants** – allow the latest versions of software, products, or updates to be pushed to users live.
- Development tenants** – used for development purposes without impacting live or operational tenants.
- Staging tenants** – used for testing purposes without impacting live or operational tenants.
Select Next to proceed to the Add services step.
On the Add services step, select the checkboxes for the services that you want to make available within your new tenant.
The Orchestrator service is mandatory. Other services are only available if you have free licenses for them. -
Select Next to proceed to the License allocation step.
On the License allocation step, you can observe the available number of licenses for each type that you can allocate to your new tenant. If you want to keep some of the available licenses for other tenants, you can allocate a lower number of licenses to your new tenant from each of the available license types.
Select Create to close the wizard and create the tenant.
The new tenant is added to the Tenants panel and the tenant picker.
Production type tenants can be identified through a Production tenant icon. Non-production type tenants can be identified through a Non-production tenant icon.
To be able to work in the tenant, you or a service administrator must assign roles and licenses for the services in the new tenant to users. For more information, refer to:
When editing tenant settings, you can change the name, color, enable, disable, or delete the tenant.
Changing the tenant name or color
- Go to Admin and select the tenant in the panel on the left.
- Select Settings.
The Settings page for the selected tenant opens. - Edit the tenant name if needed.
Important: Changing a tenant's name disconnects your Robots and Mobile Orchestrator users, and invalidates any pending user invites. Refer to Impact of Changing Tenant Names.
- From the list to the right of the name, select a different header color for the tenant, if needed.
- Select Save Changes at the bottom of the page.
A confirmation message appears in the top right of the screen.
Impact of changing tenant names
Changing the name of any of your tenants greatly impacts your previous UiPath service configurations:
- Robots configured at Orchestrator services level are disconnected. Update to reconnect your robots, entering the new URLs.
- Service URLs previously bookmarked don’t work anymore. Notify users of the new URLs.
- Mobile Orchestrator users are disconnected. Provide new service URLs to reconnect.
Enabling or disabling a tenant
Disabled tenants remain visible to organization administrators in the Tenants panel of the Admin page, but the tenant and its services are no longer available to users. Also, the licenses that were allocated to the tenant are released and returned to the organization's pool of licenses.
All data for the services is kept. You can later enable the tenant to access its services again.
- Select Settings.
The Settings page for the selected tenant opens. - Under Disable Tenant, select Enable or Disable, depending on the current state of the tenant.
- A warning dialog opens.
- In the dialog, select Enable or Disable to proceed.
A loading icon is shown next to the tenant in the Tenants panel on the left while the change is being processed.
After the icon disappears:
- If you disabled the tenant, Disabled appears to its right and the tenant and its services are no longer available to users.
- If you enabled the tenant, it is now restored as it was before being disabled. All licenses that it used before are also re-allocated if they were available in the organization pool. The tenant and its services are now available for use.
Deleting a tenant
When deleting a tenant, you remove the tenant from your organization and also delete all of its services and any service data.
After deleting a tenant, all its licenses are freed up and available for you to allocate to other tenants.
If any processes are being executed in the tenant's Orchestrator service, you cannot delete the tenant.
- Select Settings.
The Settings page for the selected tenant opens. - Under Delete permanently, select Delete, depending on the current state of the tenant.
- The Delete Tenant dialog opens.
- In the field, enter the tenant name, exactly as it is shown, including the letter case, and then select Delete.
A loading icon is displayed next to the tenant in the Tenants panel while the deletion is in progress. When complete, the tenant is removed from the Tenants panel.
Editing tenant licenses
In Admin > Tenant > Licenses, you can view information about the licenses currently allocated to each tenant.
To change the license quantities, select Edit allocation in the top right corner.
For more information, refer to Allocating licenses to tenants.
