Automation Suite admin guide
Custom email settings
SMTP configuration fields for custom email settings in Automation Suite, including hostname, port, TLS, authentication, sender address, and sender name options.
To configure custom email settings for your own SMTP server, provide the necessary information for your SMTP configuration, as described in the following table:
SettingDescriptionExample
HostnameThe SMTP server that handles the sending of your emails.Smtp.office.com
DomainThe email server responsible for handling emails.Provider.com
PortThe communication port used for sending emails. Port 25 is commonly used, but some email providers also offer ports like 587.25
TimeoutMaximum duration that the system waits for a response from the SMTP server. If the server does not respond within the specified timeout period, the attempt is considered unsuccessful.180,000 ms
Use TLS encryptionWhen enabled, it ensures that sensitive data remains confidential during transit.N/A
Require authenticationWhen enabled, you should provide valid credentials (username and password) before the system is allowed to send emails through the SMTP server.Username: name@name.com Password: ********
Sender addressThe email address that is used as the source of the emails being sent. It represents the identity of the sender and is displayed in the recipient's inbox as the address from which the email originated.admin@mydomain.com
Sender nameThe human-readable name associated with the sender's email address. It appears alongside the sender's email address in the recipient's inbox.mydomain.com mailer
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
