maestro-automate
Guide de l'utilisateur de Maestro Automate
Commutateur (Switch)
Configurez le nœud Basculer, écrivez ses expressions de cas et choisissez entre Basculer et Décision, avec des exemples.
Ce qu’il fait​
Routes a workflow to one of several paths based on ordered conditions. By default, the first condition that matches is taken. With Match all cases turned on, every case whose condition is true runs its branch.
Choix entre Basculer et Décision​
Utiliser Basculier lorsque...Utiliser la décision lorsque...
Vous avez trois résultats ou plusVous avez exactement deux résultats
Vous effectuez le routage selon plusieurs conditions distinctesLa condition est un simple oui/non
Vous avez besoin d'une branche par défaut/de secours
Référence de la configuration​
ChampRequisDefaultDescription
Switch casesOui (Yes)2 cas videsOrdered branch list, up to 10 cases. Each case has a label and a Condition, a JavaScript expression that returns true or false. The first case whose condition is true is taken.
Default branchNon (No)SurAdds a Default path that runs when no other condition matches.
Match all casesNon (No)Désactivé (Off)When on, the flow continues down every case whose condition is true, not only the first. To continue after the matched branches, connect them to a Merge node, which waits only for the branches that ran.
Écriture d'expressions de cas​
Chaque expression de cas utilise le même environnement JavaScript que les nœuds Script et Décision :
// Case 1: high priority
$vars.ticket1.output.priority === "high"
// Case 2: medium priority
$vars.ticket1.output.priority === "medium"
// Case 3: low priority (or use Default to catch everything else)
$vars.ticket1.output.priority === "low"
More specific conditions should appear first. A broader condition higher in the list will match before a more specific one below it. With Match all cases turned on, the order doesn't decide which branch runs, because every matching case runs.
Exemples​
Exemple 1: acheminer par code de statut HTTP​
CasExpressionBranche
Réussite$vars.httpRequest1.output.code === 200traiter la réponse
Introuvable$vars.httpRequest1.output.code === 404gérer la ressource manquante
Default(repli)gérer l’erreur inattendue
Exemple 2: Routez par valeur de chaîne​
Approuvé$vars.form1.output.status === "approved"Continuer le workflow
Rejeté$vars.form1.output.status === "rejected"notifier le rejet
En attente$vars.form1.output.status === "pending"attendre la révision
Default(repli)gérer le statut inconnu
Prochaines étapes​
