maestro-automate
Guide de l'utilisateur de Maestro Automate
DocuSign
Look up the DocuSign connector: its actions and events in alphabetical order, and the sign-in methods of a DocuSign connection.
The DocuSign connector lets a workflow create and send envelopes for e-signature, and download their documents. In the Add node panel, it's in the Connector category, under DocuSign. How connector nodes work describes how a connector node is set up.
This page lists what the connector can do in Maestro Automate. Select an action or event to see how to configure it.
Actions​
Each action is a node that does one thing in DocuSign.
ActionCe qu’il fait
Ajouter un document à l'enveloppeAjoutez un document à une enveloppe existante dans DocuSign.
Ajouter un destinataire à l'enveloppeAjouter un destinataire à une enveloppe existante dans DocuSign.
Créer une enveloppeCreate and send a document envelope using DocuSign.
Create Envelope using TemplateCreate and manage envelopes using templates in DocuSign, either saving as draft or sending to recipients.
Créer à partir d'une enveloppe existanteCreate a draft copy of an existing envelope in DocuSign.
Delete RecordDelete a record in DocuSign.
Télécharger les documents de l'enveloppeDownload all documents from a DocuSign envelope.
Récupérer une enveloppeRetrieve the status of an envelope in DocuSign.
Récupérer les données d'un formulaireRetrieve envelope and tab data from in-process, completed, or canceled envelopes in DocuSign.
Obtenir l'enregistrementRetrieve a record in DocuSign.
Récupérer un modèleRetrieve the definition of a template in DocuSign.
Insert RecordInsert a new record in DocuSign.
Lister tous les destinataires de l'enveloppeRetrieve a list of recipients for a specific envelope in DocuSign.
Lister tous les enregistrementsList all records in DocuSign.
List documents in envelopeList all documents in an envelope.
Remplacer l'enregistrementReplace a record in DocuSign.
Envoyer une enveloppeSend a draft envelope using DocuSign.
Events​
Each event can start a workflow, as a Connector trigger, or pause a run until it happens, as a Connector event. In the connector's list, events have the WAIT tag.
Événement (Event)Ce qu’il fait
Enveloppe crééeTriggers actions when a new envelope is created in DocuSign.
Envelope Sent to All RecipientsTriggers when an envelope is sent to all recipients in DocuSign.
Envelope Signed by All RecipientsSe déclenche lorsqu'une enveloppe est signée par tous les destinataires dans DocuSign.
Statut d’enveloppe mis à jour (Envelope Status Updated)Triggers when an envelope's status is updated in DocuSign.
Connexion (Connection)​
A DocuSign node signs in through a connection. Create a connection describes how to create one from the node. On the Connect to page, choose one of these sign-in methods:
Sign-in methodÉléments requis
Code d'autorisation OAuth 2.0Your DocuSign account ID, and the email address and password of your account.
Apportez votre propre application OAuth 2.0The client ID and client secret of an app that you create in DocuSign, your account ID, and the environment.
Only DocuSign production accounts work. Demo and developer accounts don't.
DocuSign authentication in the Integration Service guide describes the full connection setup, including prerequisites and advanced settings.
Prochaines étapes​
  • Actions​
  • Events​
  • Connexion (Connection)​
  • Prochaines étapes​
