You have been redirected to the first page of the Automation Suite documentation for the 2023.4 version.
OUT OF SUPPORT
Last updated Feb 25, 2025
Automation Suite overview
Automation Suite enables you to deploy the UiPath® business automation platform in your environment of your choice. Depending on your needs, you can deploy the platform on Linux servers (bare-metal or virtual machines) in your data center or public cloud (Azure, AWS, or GCP), or on your Kubernetes clusters in Amazon Web Services (Elastic Kubernetes Service) or Microsoft Azure (Azure Kubernetes Service).
Automation Suite includes:
  • All Server Products (except for any new products shipping in Automation Cloud first).
  • All Shared Suite Capabilities that enable you to easily configure the integration with existing enterprise systems, such as AD, AAD, or SAML, across all products; a common experience is offered across the suite for the user, tenant, external applications, and license management.
  • Common end-user portal.
This guide provides documentation for installing Automation Suite on your EKS or AKS clusters.
Key benefits
Deployment scenarios
You can deploy Automation Suite in an online environment, with or without a proxy.
Security and compliance
Automation Suite is pre-configured with optional OPA policies and network policies to follow the principles of the least privilege. In addition, to control the OPA policies, Automation Suite also bundles an optional Gatekeeper component.
Prerequisites
Before installing Automation Suite, you must make sure that your cluster meets the infrastructure requirements.
Installation
UiPath® provides the uipathctl CLI tool, which handles operations such as running prerequisite validations, installing Automation Suite on your cluster, and performing upgrades.
Post-installation management
Automation Suite provides management operations via uipathctl, such as adding new products, updating certificates, configuring Automation Suite in maintenance mode, taking backups, and monitoring.
Upgrade and migration
This section provides more details on how to upgrade Automation Suite or your infrastructure underneath Automation Suite, and how to migrate from standalone products to Automation Suite.
For details, see Upgrade and Migration options.
Troubleshooting
You can run health checks and tests to help detect issues and whether they are in the infrastructure layer or within Automation Suite.
Cross-deployment model feature comparison
We aim to provide feature parity between our Automation Suite deployment models. However, there will always be some differences you should be aware of.
User scenario/FeatureAutomation Suite on LinuxAutomation Suite on AKSAutomation Suite on EKS
Service capabilities
Orchestrator
available
availableavailable
AI Centeravailableavailableavailable
AI Center with external orchestrator (standalone)available
not available
not available
Appsavailableavailableavailable
Action Centeravailableavailableavailable
Automation Hubavailableavailableavailable
Automation Opsavailableavailableavailable
Data Serviceavailableavailableavailable
Document Understandingavailableavailableavailable
Insightsavailableavailableavailable
Automation Suite Robotsavailableavailableavailable
Process Miningavailableavailableavailable
Task Miningavailableavailableavailable
Test Manageravailableavailableavailable
Integration Service
not available
not availablenot available
Communications miningnot availablenot availablenot available
Studio Webnot availablenot availablenot available
Architecture
KubernetesRancher RKE2AKSEKS
Databases
MS SQL
Note:
Additional Microsoft SQL platforms, such as Azure SQL Database or Azure SQL Managed Instance, as well as Amazon Relational Database Service are also supported as long as the Microsoft SQL Server database engine meets the requirements.
Storage
  • Option 1: Embedded block storage (Longhorn) and Object Storage (Ceph)
  • Option 2: Embedded block storage (Longhorn) and Object storage external to the cluster
UiPath provides the Longhorn and Ceph.
  • Object Storage: Azure Blob
  • Filesystem: Azure Filesystem
  • Block Storage: Azure Disks
  • Object Storage: AWS S3
  • Filesystem: AWS EFS
  • Block Storage: AWS EBS
Service Mesh and Routing
Rancher provided Istio Service Mesh, Routing via envoy ingress gateway
OSS Istio Service Mesh Routing via WASM plugin
OPA
OSS Gatekeeper
OSS Gatekeeper
OSS Gatekeeper
Monitoring
Rancher provided Prometheus & Grafana
OSS Prometheus & Grafana
Caching
Embedded Redis with in the cluster and provided by UiPath
Cloud Redis outside the cluster and managed by customer
Logging Aggregation
Rancher provided Fluend/Fluent-bit
OSS Fluend/Fluent-bit
Cert Manager
OSS Cert Manager
OSS Cert Manager
OSS Cert Manager
Deployment tool
OSS ArgoCD
OSS ArgoCD
OSS ArgoCD
Deployment scenario
Single Node (Non-production)
available
not available
not available
Multi Node (HA)
available (requires additional HAA license)
available
available
Online
available
availableavailable
Offlineavailable
not available
not available
Deployment method
Advanced CLIinstall-uipath.sh
uipathctl
uipathctl
Interactive Installer
available (InstallUipathAS.sh)
not available
not available
Cloud deployment templates
available (AWS, Azure, GCP)
not available
not available
Marketplace
available (AWS QS Only)
not available
not available
Installation
A la carte product selection
available
availableavailable
Custom domainavailableavailableavailable
Custom certificatesavailableavailableavailable
Hardware requirements validationavailableavailableavailable
Proxy configurationavailableavailableavailable
Optional OSS/fabric component
not available
availableavailable
Enterprise grade features
Disaster Recovery
available (Active Passive deployment)
available
(Multi-zone architecture for UiPath services without zone affinity. Insights not supported.)
available
(Multi-zone architecture without zone affinity. Insights not supported.)
Backup/restoreavailableavailableavailable
Upgrade
available
availableavailable
Troubleshooting
Support bundleavailable
(support-bundle.sh)
not available
not available
Diagnostic toolavailable
(diagnostics-report.sh)
available
(uipathctl)
available (uipathctl)
Health Checks
not available
available (uipathctl) available (uipathctl)
Security
FIPS enabled host
available
not available
not available
Gatekeeper/OPA policyavailableavailableavailable
Network policy
not available
availableavailable
Hardened Uipath service container imagesavailableavailableavailable
ArgoCD SSOavailable (LDAP only)
available
available
mTLS for service communication
available
available
available
Migration options
Standalone Orchestrator to Automation Suite full migrationavailableavailableavailable
Standalone Orchestrator to Automation single tenant migration optionsavailableavailableavailable
Automation Suite embedded to AS on AKS/EKS
not available
not available
not available
Evaluation guide
Requirements and installation
Details
Instructions
Requirements and installation instructions for Automation Suite.
Platform evaluation
Details
Instructions
Complete an initial platform configuration.
Connect your first robot
Monitor the stack, troubleshoot issues, create alerts, and view dashboards from a centralized location.
