- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Prerequisite checks
It is recommended to run prerequisite checks to ensure that you properly configured the cloud infrastructure and to validate input.json before starting the Automation Suite installation.
You can run a prerequisite check using the `` command. By default, this command verifies all the prerequisites. If you want to exclude components from the execution, use the --excluded flag.
The checks in the following table are run on each node:
| Check | Description |
SQL Connection |
Validates that Automation Suite can successfully connect to SQL server for UiPath products and shared services (such as Identity,
Portal, Org Mamagement, etc.) using the SQL connection strings provided in |
SQL DB roles |
Validates the necessary roles and permissions required by UiPath products. This is mandatory for a successful installation. |
SQL DB compatibility |
Validates SQL DB compatibility requirements. |
FQDN resolution |
Validates that the FQDN and the sub-domains are successfully resolvable. |
Object Storage API |
Validates that Object store APIs are accessible based on access information provided in |
Cache / Redis |
Validates the connection to Cloud Redis or ElastiCache. This is mandatory for a successful installation. |
Capacity |
Validates you have minimum worker nodes' CPU and RAM capacity based on products enabled in |
Storage Class |
Validates the storage classes for File Storage are configured as required for Automation Suite Robots. |
Optional Components |
Validates that your cluster has components that you chose to exclude from the Automation Suite installation. |
Ingress |
Validates that the cluster ingress is configured correctly and the FQDN URL requests can reach UiPath products. |
Network Policies |
Checks if network policies configured in Automation Suite are compatible with the cluster. |
Registry |
Validates that Automation Suite can access the UiPath docker registry. This is mandatory for a successful installation. |
Cluster Connectivity |
Validates whether the cluster communication is configured properly:
