AKS upgrades cause Automation Suite to fail
Description​
An upgrade known issue affecting AKS causes Automation Suite 2023.4.1-2023.4.5 to fail. When trying to upgrade AKS, the argocd-redis-ha-server pod is put in error state.
Solution​
To fix the issue, take the following steps:
  1. Uninstall the existing ArgoCD chart by running the following command. Note that the kubeconfig path should be set to the cluster path.
    helm uninstall argocd -n argocd
  2. Search for the profile key in the root level of input.json.
    • If it is present, change the value of the profile key to default.
    • If not present, add the "profile":"default" key in the root level ofinput.json.
  3. Reinstall the ArgoCD chart by running the following command:
    uipathctl manifest apply input.json --versions versions.json --only argocd
  • Description​
  • Solution​
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
