- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
If you use Active Directory (AD) and are planning on upgrading to 2023.4.0, we highly recommend that you skip straight to the 2023.4.3 version, as 2023.4.0, 2023.4.1 and 2023.4.2 are impacted by an AD issue.
Automation Suite on AKS/EKS consists of multiple components. Both you as a customer and UiPath share responsibility of these components. For details, see Compatibility matrix.
You are responsible for upgrading:
- Kubernetes infrastructure where Automation Suite is deployed (AKS or EKS)
- Components that you choose to bring as part of Automation Suite (e.g., Gatekeeper, FluentD, etc.)
UiPath is responsible for upgrading:
- UiPath services (e.g., Orchestrator)
- Components deployed as part of Automation Suite (e.g., ArgoCD)
Preparation
There is a known issue with the backup logic in Automation Suite for AKS/EKS versions 2023.10.0 to 2023.10.7. Specifically, this issue excludes the backup of Insights dashboards. However, all historical data is successfully backed up.
Execution
To perform an upgrade of UiPath® services and component, take the following steps:
You are responsible for upgrading the Kubernetes infrastructure hosting Automation Suite. You should follow the standard practices of your company to upgrade Kubernetes infrastructure.
