- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- Step 1: Saving the connection strings
- Step 2: Creating your organizations in Automation Suite
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Save the following information for further usage:
- The connection string for the Orchestrator database in the standalone deployment;
- The connection string for the Insights database in the standalone deployment;
AutomationSuite_Platformdatabase in the Automation Suite deployment. You can retrieve the connection string from theinput.jsonfile, under theplatformparameter.
