- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
To update credentials for the different Automation Suite components, take the following steps:
Generate the
file.input.json -
Provide the new credentials for the given components in the
as described in each component section.input.json -
Run the
uipathctlCLI as described in each component section.
input.json file as follows:
A: Run the following command to get the latest revision of your
file:input.jsonuipathctl manifest get-revisionuipathctl manifest get-revision -
B: Run the following command to list all the past
files and determine the one you wish to choose:input.jsonuipathctl manifest list-revisionsuipathctl manifest list-revisions
There are multiple scenarios where you may want to update the connection string used by Automation Suite products to connect to the SQL database, such as the following:
- When periodically rotating the password used to connect to the database, for security and compliance
- When changing the FQDN for the SQL server
- When migrating the database to another SQL server for maintenance purposes
- When adding, modifying, or removing one or more connection attributes, such as
MultiSubnetFailover - When switching from basic authentication to integrated authentication using Kerberos and AD
Important:
Products in Automation Suite do not create tables or schema at the time of updating the SQL database connection string. Make sure your new connection string refers to the same database that you currently use.
To avoid downtime during the update process, make sure that your current connection string is valid at the time of the update process. You can revoke your old connection string after the update.
Updating the connection strings for installed products
- Generate the
file.input.json - Provide the new connection strings for the installed products in the
input.json. - Run
uipathctl.
Providing the new connection strings for installed products
There are two ways to provide the connection strings for products running in Automation Suite:
A: Provide a connection string template that will be common to all the products running in Automation Suite. This approach will assume the default database names for all the products.
B: Provide connection strings specific to each product.
Make sure you escape NET, JDBC, or ODBC passwords as follows:
for NET: add
'at the beginning and end of the password, and double any other'. -
for JDBC/ODBC: add
{at the beginning of the password and}at the end, and double any other}.
TrustServerCertificate=False, then you may have to provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate
is self-signed or signed by an internal CA. For details, see Updating the CA certificates.
A: Providing a common connection string for all products
All the products running in Automation Suite refer to a common template connection string. One use case for choosing this method would be when you want to change the password for all the products at once. Note that, in this case, the password will be the same for all the products.
In this scenarios, the database names for all products must be the default ones, as required by Automation Suite. If the database names you configured do not meet the Automation Suite requirements, follow the next step.
The following table explains which template format the product services accept:
Parameter |
Description |
Products |
Full ADO.NET connection string where Catalog name is set to
DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
Platform, Orchestrator, Automation Suite Robots, Test Manager, Automation Hub, Automation Ops, Insights, Task Mining, Data Service, Process Mining |
Full JDBC connection string where database name is set to
AI Center |
Full ODBC connection string where database name is set to
Document Understanding, Apps |
sql_connection_string_template_sqlalchemy_pyodbc | Full SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.
Process Mining |
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
"mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server""mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"input.json with the new connection string template you want to update.
B: Providing connection strings specific to each product
Platform
AutomationSuite_Platform.
input.json file:
"platform": {
"sql_connection_str": "***" // dotnet connection string
}"platform": {
}Orchestrator
AutomationSuite_Orchestrator.
input.json file:
"orchestrator": {
}"orchestrator": {
}Automation Suite Robots
input.json file:
"asrobots": {
}"asrobots": {
}Automation Hub
AutomationSuite_Automation_Hub.
input.json file:
"automation_hub": {
}"automation_hub": {
}Automation Ops
input.json file:
"automation_ops": {
}"automation_ops": {
}AI Center
AutomationSuite_AICenter.
input.json file:
"aicenter": {
"sql_connection_str": "***" // jdbc connection string
}"aicenter": {
}Apps
AutomationSuite_Apps.
input.json file:
"apps": {
"sql_connection_str": "***" // odbc connection string
}"apps": {
}Data Service
AutomationSuite_DataService.
input.json file:
"dataservice": {
}"dataservice": {
}Document Understanding
AutomationSuite_DU_Datamanager.
input.json file:
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "***" // dotnet connection string,
"datamanager": {
}"documentunderstanding": {
"enabled": true,
"datamanager": {
}Insights
AutomationSuite_Insights.
input.json file:
"insights": {
}"insights": {
}Process Mining
AutomationSuite_ProcessMining_Metadata.
input.json file:
"process_mining": {
"enabled": true,
"sqlalchemy_pyodbc_sql_connection_str": "",
"warehouse": {
"sql_connection_str": "",
"master_sql_connection_str": "",
}"process_mining": {
"enabled": true,
"warehouse": {
}Task Mining
AutomationSuite_Task_Mining.
input.json file:
"task_mining": {
}"task_mining": {
}Test Manager
AutomationSuite_Test_Manager .
input.json file:
"test_manager": {
}"test_manager": {
}Running the uipathctl installer
uipathctl installer using the following command:
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.jsonProviding the new credentials for Redis
input.json file
with the new password and/or hostname:
"fabric": {
"redis": {
"hostname": "new_hostname",
"password": "new_password",
"port": 6380,
"tls": true
}"fabric": {
"redis": {
"port": 6380,
"tls": true
uipathctl manifest apply input.json --only redis --versions versions.jsonuipathctl manifest apply input.json --only redis --versions versions.jsonuipathctl to print the result of the command without applying it.
input.json file with the new access_key, secret_key or acount_key and account_name:
"external_object_storage": {
"enabled": false, // <true/false>
"create_bucket": true, // <true/false>
"storage_type": "s3", // <s3,azure,aws>
"fqdn": "", // <needed in case of aws non instance profile>
"port": 443, // <needed in case of aws non instance profile>
"region": "",
"access_key": "", // <needed in case of aws non instance profile>
"secret_key": "", // <needed in case of aws non instance profile>
"use_managed_identity": false, // <true/false>
"bucket_name_prefix": "",
"bucket_name_suffix": "",
"account_key": "", // <needed only when using non managed identity>
"account_name": "",
"azure_fqdn_suffix": "core.windows.net",
"client_id": "" // <optional field in case of managed identity>
},"external_object_storage": {
"region": "",
"account_name": "",
},Running the uipathctl installer
uipathctl manifest apply input.json --versions versions.jsonuipathctl manifest apply input.json --versions versions.jsonuipathctl to print the result of the command without applying it.
uipathpullsecret. To update uipathpullsecret, take the following steps:
- Update the registry section of the
input.jsonfile:"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" } }"registries": { "docker": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" }, "helm": { "url": "yourContainerRegistryUrl", "username": "username", "password": "newpassword" } } - Delete the existing
uipathpullsecret:kubectl delete secret uipathpullsecret -n uipath kubectl delete secret uipathpullsecret -n uipath-installerkubectl delete secret uipathpullsecret -n uipath kubectl delete secret uipathpullsecret -n uipath-installer - Rerun the installation command:
- Guidelines
- Generating the input.json file
- Guidelines
- Updating the SQL connection strings
- Updating the connection strings for installed products
- Updating Redis credentials
- Providing the new credentials for Redis
- Running the uipathctl installer
- Updating objectstore credentials
- Updating the registry credentials
