- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Performing database maintenance
- Forwarding application logs to Splunk
- Troubleshooting
- This section covers exporting POD logs. For exporting robot logs, see Ochestrator - About Logs.
- Splunk is an external tool, and UiPath® does not have an opinion on how you should configure your Splunk setting. For more details about HTTP Event Collector, see Splunk official documentation.
The Splunk-Fluentd stack is a centralized logging solution that allows you to search, analyze, and visualize log data. Fluentd collects and sends the logs to Splunk. Splunk retrieves the logs and lets you visualize and analyze the data.
Creating a secret with a token
Create a Kubernetes secret with the HTTP Event Collector (HEC) token generated in the Splunk UI. This token is used for the authentication between Automation Suite and Splunk.
kubectl -n logging create secret generic splunk-hec-token --from-literal=splunk_hec_token=<splunk_hec_token>
ClusterOutput to Splunk
A ClusterOutput defines where your logs are sent to and describes the configuration and authentication details.
To configure the ClusterOutput for Splunk, run the following command:
kubectl -n logging apply -f - <<"EOF"
apiVersion: logging.banzaicloud.io/v1beta1
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey: <splunk_hec_timekey>
timekey_use_utc: true
timekey_wait: 10s
type: file
hec_host: <splunk_hec_host>
hec_port: <splunk_hec_port>
hec_token:
valueFrom:
secretKeyRef:
key: splunk_hec_token
index: <splunk_hec_index>
insecure_ssl: true
protocol: <splunk_hec_protocol>
source: <splunk_hec_source>
sourcetype: <splunk_hec_source_type>
EOF
kind: ClusterOutput
metadata:
spec:
splunkHec:
buffer:
tags: '[]'
timekey_wait: 10s
type: file
hec_token:
valueFrom:
secretKeyRef:
insecure_ssl: true
EOF
Replace the attributes between angle brackets < > with the corresponding values used in your Splunk configuration. For details, see the following table:
| Attribute | Description |
splunk_hec_host | The network host of your Splunk instance. This is usually the IP address or FQDN of Splunk. |
splunk_hec_port | The Splunk port for client communication. This port usually differs from the port on which you launch the Splunk dashboard. The conventional HEC port for Splunk is 8088. |
secret_key | The secret key of the Splunk token. This is the name of the key in the secret you created in the previous step, which holds Splunk HEC token. The presented manifest already contains the key: splunk_hec_token. If you have not altered the command to create a secret, you do not need to change this value. |
splunk_hec_timekey value in splunkHec.buffer | The output frequency, or how often you want to push logs. We recommend using a 30-seconds (30s) interval. |
protocol | The URL protocol. Valid values are http and https. You must use HTTPS protocol if you have SSL communication enabled on Splunk. |
splunk_hec_index | The identifier for the Splunk index. Used to index events. |
splunk_hec_source | The source field for events. |
splunk_hec_source_type | The source type field for events. |
To filter logs in Splunk by environment type (dev, test, etc.), use the source attribute.
The following example is based on the configuration presented on this page.
ClusterFlow in Fluentd
Use the ClusterFlow to define:
- the logs you want to collect and filter;
- the
ClusterOutputto send the logs to.
To configure ClusterFlow in Fluentd, run the following command:
kind: ClusterFlow
metadata:
namespace: logging
spec:
filters:
- tag_normaliser:
format: ${namespace_name}/${pod_name}.${container_name}
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- aicenter-hit-count-update
- istio-configure-executor
- on-prem-tenant-license-update
- curl
- recovery
- aicenter-oob-scheduler
- cert-trustor
- exclude:
namespaces:
- default
- exclude:
labels:
app: csi-snapshotter
- exclude:
labels:
longhorn.io/job-task: backup
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
kind: ClusterFlow
metadata:
namespace: logging
spec:
filters:
- tag_normaliser:
globalOutputRefs:
- splunk-output
match:
- select:
container_names:
- istio-proxy
namespaces:
- istio-system
- exclude:
container_names:
- istio-proxy
- istio-init
- curl
- recovery
- cert-trustor
- exclude:
namespaces:
- default
- exclude:
labels:
- exclude:
labels:
- exclude:
labels:
app: csi-resizer
- select: {}
EOF
Searching in Splunk
Select Search & Reporting.
Search based on Source, Index, and SourceType.
Troubleshooting
If, for some reason, the application logs are not pushed to Splunk, take the following steps:
Change the Fluentd log level to debug.
Query the Fluentd pod:
kubectl patch logging -n logging logging-operator-logging --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n logging exec -it sts/logging-operator-logging-fluentd cat /fluentd/log/outkubectl patch logging -n logging logging-operator-logging --type=json -p '[{"op":"add","path":"/spec/fluentd/logLevel","value":debug}]' kubectl -n logging exec -it sts/logging-operator-logging-fluentd cat /fluentd/log/outNote:The Fluentd logs should indicate the cause of data not being pushed to Splunk.
After fixing the issue, restore the Fluentd log level:
kubectl patch logging -n logging logging-operator-logging --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel","value":debug}]'kubectl patch logging -n logging logging-operator-logging --type=json -p '[{"op":"remove","path":"/spec/fluentd/logLevel","value":debug}]'
