- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Compatibility matrix
Azure third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on AKS.
| Prerequisites for Azure | Compatible versions |
| Azure Kubernetes Service (AKS) Architecture | x86 |
| Ubuntu | 18.04, 22.04 |
| Cloud Redis | Version 6 |
| Microsoft SQL Server | Microsoft SQL Server 2016, 2017, and 2019 Standard and Enterprise editions. For product-specific version dependency, see this. |
| Prometheus (if you bring your own) | 2.53.0 |
| Grafana (if you bring your own) | 11.1.0 |
| Alert Manager (if you bring your own) | 0.27.0 |
| FluentD/Fluent-bit (if you bring your own) helm-charts: logging-operator, logging-operator-logging | 4.8.0 |
| Gatekeeper (if you bring your own) helm-charts: gatekeeper | 3.16.3 |
| Velero (if you bring your own) helm-charts: velero | 6.2.0 |
| Cert Manager (if you bring your own) helm-charts: cert-manager | 1.14.5 |
AWS third-party component compatibility
The following table lists the third-party software compatible with the latest version of Automation Suite on EKS.
| Prerequisites for AWS | Compatible versions |
| Elastic Kubernetes Service (EKS) Architecture | x86 |
| RHEL | 8.8 for EKS 1.27 |
| Amazon Linux | 2 for all EKS versions |
| Elasticache | version 6.2.6 |
| Database - RDS | 15.00.4236.7.v1 |
Kubernetes compatibility
To receive UiPath® support for a particular Automation Suite Cumulative Update (CU), you must use both an Automation Suite version and a Kubernetes version that are currently supported.
The support calendar for Automation Suite is available in the Product lifecycle section of the Overview guide. For the Kubernetes support calendar, see the Kubernetes documentation.
Updating your Kubernetes cluster to a supported version may require updating Automation Suite to a newer CU. For example, if you are on Automation Suite 2023.4.1, the last supported version for your cluster is Kubernetes 1.27. As this version reached its end of life, you must update your cluster to a newer Kubernetes version. This also requires updating to a newer Automation Suite CU.
The following table lists the Kubernetes versions compatible with each Automation Suite 2023.4.x CU.
| Automation Suite version | Compatible Kubernetes versions |
| 2023.4.8 | 1.28, 1.29 , 1.30 |
| 2023.4.7 | 1.28, 1.29 , 1.30 |
| 2023.4.6 | 1.27, 1.28, 1.29 |
| 2023.4.5 | 1.26, 1.27, 1.28 |
| 2023.4.4 | 1.25, 1.26, 1.27 |
| 2023.4.3 | 1.25, 1.26, 1.27 |
| 2023.4.2 | 1.24,1.25,1.26 |
| 2023.4.1 | 1.24,1.25,1.26 |
