- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
A) Full migration
The full migration is one of two ways in which you can migrate a standalone UiPath product to Automation Suite. This method helps you migrate Orchestrator and other products and services. For more information, see Migration options.
We tested the migration for Orchestrator, Action Center, and Test Automation, which share the same database, as well as for Insights.
The full migration options also ensures high-fidelity data transfer between the standalone product databases and the automatically created Automation Suite databases. If you do not want to use the default Automation Suite databases, you can opt for your own migrated databases provided that you update their connection strings.
To migrate from a standalone deployment to Automation Suite, take the following steps:
Description |
Instructions |
1. Upgrade your standalone deployment. |
2. Deploy Automation Suite. |
3. Make sure you meet the requirements. |
4. Follow the pre-migration steps. |
| 5. Follow the migration steps. |
6. Follow the post-migration steps. |
