- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
To back up the the database of the shared platform capabilities in Automation Suite, take the following steps. Note that the default name of this database is AutomationSuite_Platform.
Log into the Automation Suite SQL Server using SSMS.
Right-click Database, select Tasks, and then Export Data-tier Application.
Select the output path for the
BACPACfile. -
Finish the process.
