- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- Step 1: Removing old cache keys
- Step 2: Updating AD integration and authentication
- Step 3: Validating the Insights migration
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
To configure AD integration, refer to Configuring SSO: Active Directory.
If AD integration and authentication were enabled in the standalone deployment, take the following steps in the Automation Suite cluster:
Make sure the domain controllers are discoverable by the Automation Suite cluster. If not, use the Kube DNS configuration;
Configure integrated Windows authentication and Kerberos authentication using keytab file;
Configure LDAP integration via the Portal under the host admin;
Configure Windows authentication via the Portal under the host admin;
Configure LDAPS for secure connection to LDAP.
Note:The account used for the LDAP integration configuration should only have read access to all trusted domains in the current and trusted forests.
