- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Rotating Blob Storage Credentials
- Disabling use of pre-signed URLs when uploading data to Amazon S3 storage
- Configuring process app security
- Setting up Kerberos authentication with basic MSSQL authentication for Process Mining
- Troubleshooting
If you use Amazon S3 storage objects and you want to prevent users uploading data using a pre-signed URL, you can configure this in the blob_storage_account_use_presigned_uri setting in the cluster_config.json file.
By default, the blob_storage_account_use_presigned_uri setting is set to true. If you do not want users to upload data using a pre-signed URL, you can set the blob_storage_account_use_presigned_uri setting to false.
