- Overview
- Requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
Managing the certificates
The installation process generates self-signed certificates on your behalf. You should replace them with certificates signed by a trusted Certificate Authority (CA) as soon as installation completes.
You can use the uipathctl CLI tool to update certificates post-installation. For details, see uipathctl documentation.
Generating a Certificate Signing Request (CSR) and a private key
To generate the CSR and the private key, run the following command:
# copy the machine openssl configuration locally
cp /etc/pki/tls/openssl.cnf ./openssl.tmp.cnf
# Replace the [AUTOMATION_SUITE_FQDN] value. For example, "automationsuite.corp.com"
AS_FQDN=[AUTOMATION_SUITE_FQDN]
cat >> ./openssl.tmp.cnf <<EOF
[SAN]
subjectAltName=DNS:$AS_FQDN,DNS:alm.$AS_FQDN,DNS:monitoring.$AS_FQDN,DNS:registry.$AS_FQDN,DNS:objectstore.$AS_FQDN,DNS:insights.$AS_FQDN
EOF
# create the certificate request
openssl req -new -sha256 -newkey rsa:2048 -nodes -keyout server.key -subj "/C=xx/ST=xx/O=xx/OU=xx/CN=$AS_FQDN" -reqexts SAN -config openssl.tmp.cnf -out ${AS_FQDN}.csr
[SAN]
EOF
Your IT team uses the obtained values to generate a signed certificate. The generated private key remains local.
Managing the TLS certificate
To view more information about updating the TLS certificates, run the following command:
uipathctl config update-tls-certificates --help
Output:
Manage tls certificates
Usage:
uipathctl config tls-certificates [flags]
uipathctl config tls-certificates [command]
Available Commands:
get Get the current tls certificates
update Update tls certificates
Flags:
-h, --help help for tls-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Finding the TLS certificates
Certificates are stored as a secret at Istio level. You can find certificates under the istio-ingressgateway-certs name in the istio-system namespace.
See the certificate files in the following list:
- Server TLS certificate is stored as
tls.crt - Server TLS private key as
tls.key - CA bundle is stored as
ca.crt
You can verify the secrets using the following command:
kubectl -n istio-system get secrets istio-ingressgateway-certs -o yaml
Certificates are also stored in the UiPath namespace. This is applicable to every UiPath® product that needs certificate information to trust incoming calls. For details, see Understanding the container architecture related to certificates.
Updating the TLS certificates
You must decrypt the certificate key before updating the server certificate. Skipping the decryption step would result in an error.
To decrypt the certificate key, run the following command:
# replace /path/to/encrypted/cert/key to absolute file path of key
# replace /path/to/decrypt/cert/key to store decrypt key
# Once prompted, please entry the passphrase or password to decrypt the key
openssl rsa -in /path/to/encrypted/cert/key -out /path/to/decrypt/cert/key
To update the certificate, run the following uipathctl command. You need the path to each of the three certificate files. All the certificate file should be in pem format.
- Certificate Authority Bundle - This bundle should contain only the chain certificates used to sign the TLS server certificate. The certificate provided in the
--cacertoption should not include the leaf certificates. The chain limit is up to nine certificates. - Server Certificate - Public server certificate
- Private key - Private key for server certificate
uipathctl config tls-certificates update --cert server.crt --cacert ca.crt --key server.key
Accessing the TLS certificate
To print out the certificate files, run the following command:
uipathctl config tls-certificates get
Managing additional CA certificates
To view more information about additional CA certificates, run the following command:
uipathctl config additional-ca-certificates --help
Output:
Manage additional ca certificates
Usage:
uipathctl config additional-ca-certificates [flags]
uipathctl config additional-ca-certificates [command]
Available Commands:
get Get the current additional ca certificates
update Update additional ca certificates
Flags:
-h, --help help for additional-ca-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Updating the CA certificates
This command helps you update or replace the existing configured CA certificates.
uipathctl config additional-ca-certificates update --cacert additional_ca.crt
The command above adds a new certificate to the list of existing certificates. if you want to replace all the previously configured certificates, make sure to append --replace at the end.
The CA Certificate bundle file should be a valid .pem format and can have more than one certificate present in it.
Accessing the CA certificates
To download the already configured CA certificates, run the following command:
uipathctl config additional-ca-certificates get
Managing identity token-signing certificates
To view more information about identity token-signing certificates, run the following command:
uipathctl config token-signing-certificates --help
Output:
Manage token signing certificates
Usage:
uipathctl config token-signing-certificates [flags]
uipathctl config token-signing-certificates [command]
Available Commands:
get Get the current token signing certificate
rotate Rotate token signing certificates
update Update future token signing certificate
Flags:
-h, --help help for token-signing-certificates
Global Flags:
Usage:
Available Commands:
Flags:
Global Flags:
Updating the certificate
To upload the new certificate to sign the token, run the following command:
The following command does not replace the existing token signing certificate.
Make sure the certificate you provide is in .pem format.
uipathctl config token-signing-certificates update --cert server.crt --key server.key
Rotating the certificate
To rotate or replace the old certificate with the new one, run the following command:
uipathctl config token-signing-certificates rotate
After rotation, restart deployments and stateful sets by running the following commands:
kubectl -n uipath rollout restart deploy
kubectl -n uipath rollout restart sts
Accessing the certificate
To download the current token signing certificate, run the following command:
uipathctl config token-signing-certificates get
There should be alead time of approximately 24-48 hours between certificate update and rotate.
We need this lead time to keep supporting the authentication for cached token signed by old certificate.
Rotating the certificate too soon before the expiry of the cache token can result in downtime. In this case, you may have to restart all your robots.
- Generating a Certificate Signing Request (CSR) and a private key
- Managing the TLS certificate
- Finding the TLS certificates
- Updating the TLS certificates
- Accessing the TLS certificate
- Managing additional CA certificates
- Updating the CA certificates
- Accessing the CA certificates
- Managing identity token-signing certificates
- Updating the certificate
- Rotating the certificate
- Accessing the certificate
