- Overview
- Requirements
- Kubernetes cluster and nodes
- Proxy
- SQL database
- Caching
- Storage
- Configuring NGINX ingress controller
- Certificate requirements
- Migration and upgrade
- Upgrading Automation Suite on EKS/AKS
- Migration options
- B) Single tenant migration
- Monitoring and alerting
- Cluster administration
- Troubleshooting
OUT OF SUPPORT
Last updated Feb 25, 2025
In standard configuration, Automation Suite provisions a Load Balancer Kubernetes service type configured with Istio Gateway as an ingress controller for the requests coming from the network load balancer.
If you already have an NGINX ingress controller in your cluster and want to continue to use it, you must configure the Kubernetes
service_type as cluster_IP instead of Load Balancer. This document provides the necessary changes required for that configuration.
Important:
To manage large headers, adjust the
proxy-buffer-size in the ingress annotation as follows:
nginx.ingress.kubernetes.io/proxy-buffer-size: "8k"nginx.ingress.kubernetes.io/proxy-buffer-size: "8k"Updating your NGINX ingress configuration
You must update your NGINX specification with
istio-ingressgateway as a backend service and specify the port number 80. Additionally, if you have your own Network Policies,make sure they are
configured correctly to allow NGINX and Istio routing.
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
namespace: istio-system
spec:
ingressClassName: nginx
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
secretName: nginx-tls
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
number: 80input.json parameters
You must provide the following parameters in
input.json to change service_type and HTTPS:
"ingress": {
"service_type": "ClusterIP",
"HTTPS": false
"ingress": {
"HTTPS": false
...Updating the NGINX ingress configuration
istio-ingressgateway as a backend service and specify https as the port name.
kind: Ingress
metadata:
annotations:
nginx.ingress.kubernetes.io/backend-protocol: "https"
nginx.ingress.kubernetes.io/proxy-ssl-name: "<FQDN>"
nginx.ingress.kubernetes.io/proxy-ssl-server-name: "on"
nginx.ingress.kubernetes.io/proxy-ssl-secret: "istio-system/istio-ingressgateway-certs"
nginx.ingress.kubernetes.io/proxy-ssl-verify: "on"
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
name: httpsapiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
annotations:
spec:
tls:
- hosts:
- "<FQDN>"
- "*.<FQDN>"
rules:
- host: "<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
- host: "*.<FQDN>"
http:
paths:
- path: /
pathType: Prefix
backend:
service:
port:
name: httpsinput.json parameters
"ingress": {
"HTTPS": true
"ingress": {
"HTTPS": true
