SQL database
Note:
Unless otherwise specified in the dedicated requirements sections, these requirements are applicable to all Automation Suite products.
You must bring an external SQL server to install Automation Suite and UiPath® products. Microsoft SQL Server 2016, 2017, 2019, and 2022 Standard and Enterprise editions are supported.
Additional Microsoft SQL platforms, such as Azure SQL Database, Azure SQL Managed Instance, or Amazon Relational Database Service, are also supported as long as the Microsoft SQL Server database engine meets the requirements. For details, see Compatibility matrix.
Note:
Make sure that the SQL server can be accessed from the cluster nodes.
Individual product support varies.
For each product you plan to deploy, you must:
  • check the supported version of SQL Server as required by the product;
  • meet the SQL Server configuration requirements, including SQL Server User permissions, as required by the product.
The general minimum hardware requirements for Microsoft SQL Server are as follows:
  • 8 (v-)CPU
  • 32 GB RAM
  • 256 GB SSD
The minimum requirements are general guidance and do not guarantee reliable operation in a production deployment. Capacity planning is required to determine the hardware requirements that are needed for reliable operation. For details, see Capacity planning.
Each UiPath® product requires its own SQL database.
Database creation workflow​
The interactive installer automatically creates databases using the following workflow:
  1. The interactive installer script checks the value of the sql.create_db parameter in the input.json file.
    • If the sql.create_db parameter is set to true, the installer automatically generates all the databases on your behalf. In this case, the installer uses the default database names and default templates, and ignores any custom database names you provided.
    • If sql.create_db is set to false, you must bring your own databases. In this case, you must manually set up your databases. Note that you can use custom database names, provided that you follow the provided naming conventions. This step is critical because we use the database name in conjunction with the connection template to form the database connection string. If you do not follow the recommended naming convention, you must provide the SQL connection strings yourself.
      For details, see Bring your own databases.
  2. The interactive installer generates the connection strings as follows:
    • If you did not define a connection string for your service, the installer uses the connection template to generate all database connection strings.
    • If you defined a connection string for your service, the installer uses the provided connection string for your database.
Automatically create the necessary databases​
If you want the installer to create the databases, fill in the following fields of the input.json file:
ParameterDescription
sql.create_dbSet to true to allow the installer to create the databases. Note that the installer uses the default database names and default templates, and ignores any custom database names you provided.
sql.server_urlFQDN of the SQL server, where you want the installer to configure database.
sql.portPort number on which a database instance should be hosted in the SQL server.
sql.usernameUsername / user ID to connect to the SQL server.
sql.passwordPassword of the username provided earlier to connect to the SQL server.
Note:
  • Ensure the user has the dbcreator role. This grants them permission to create the database in SQL Server. Otherwise, the installation fails.
  • ODBC connection does not support usernames that contain special characters. For database usernames for AI Center, Document Understanding, and Apps, use only uppercase and lowercase letters.
Bring your own database​
If you choose to bring your own databases for a new Automation Suite installation, we strongly recommend setting up new databases rather than using existing ones. This precaution is necessary to prevent any conflicts with the operation of Automation Suite that might occur due to leftover metadata from old databases.
If you bring your own database, you must provide the SQL connection strings for every database. Automation Suite supports the following SQL connection string formats:
ParameterDescriptionProducts
sql_connection_string_templateFull ADO.NET connection string where Catalog name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Platform, Orchestrator, Automation Suite Robots, Test Manager, Automation Hub, Automation Ops, Insights, Task Mining, Data Service, Process Mining, Document Understanding
sql_connection_string_template_jdbcFull JDBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.AI Center
sql_connection_string_template_odbcFull ODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Document Understanding, Apps
sql_connection_string_template_sqlalchemy_pyodbcFull SQL alchemy PYODBC connection string where database name is set to DB_NAME_PLACEHOLDER. The installer will replace this placeholder with the default database names for the installed suite services.Process Mining
Important:
Make sure the SQL account specified in the connection strings is granted the db_securityadmin and db_owner roles for all Automation Suite databases. If security restrictions do not allow the use of db_owner, then the SQL account should have the following roles and permissions on all databases:
  • db_securityadmin
  • db_ddladmin
  • db_datawriter
  • db_datareader
  • EXECUTE permission on dbo schema
We only use the db_securityadmin and db_ddladmin roles during installation or if the databases are reprovisioned, so you may revoke these permission afterwards.
Insights requires the db_owner role to be assigned for a successful installation.
Important:
If you manually set the connection strings in the configuration file, you can escape SQL, JDBC, ODBC, or PYODBC passwords as follows:
  • for SQL: add ' at the beginning and end of the password, and double any other '.
  • for JDBC/ODBC: add { at the beginning of the password and } at the end, and double any other }.
  • for PYODBC: username and password should be url encoded to account for special characters. Document Understanding database passwords cannot start with {.
Important:
The AutomationSuite_ProcessMining_Airflow database for Process Mining product must have READ_COMMITTED_SNAPSHOT enabled.
Note:
By default, TrustServerCertificate is set to False, and you must provide an additional CA certificate for the SQL Server. This is required if the SQL Server certificate is self-signed or signed by an internal CA. If you do not provide the SQL Server certificate in this scenario, the prerequisite check will fail.
sql_connection_string_template example
Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net:1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;
sql_connection_string_template_jdbc example
jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net:1433;database=DB_NAME_PLACEHOLDER;user=testadmin;password=***;encrypt=true;trustServerCertificate=false;Connection Timeout=30;hostNameInCertificate=sfdev1804627-c83f074b-sql.database.windows.net"
sql_connection_string_template_odbc example
SERVER=sfdev1804627-c83f074b-sql.database.windows.net,1433;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=testadmin;PWD=***;MultipleActiveResultSets=False;Encrypt=YES;TrustServerCertificate=NO;Connection Timeout=30;"
sql_connection_string_template_sqlalchemy_pyodbc example
mssql+pyodbc://testuser%40sfdev3082457-sql.database.windows.net:_-%29X07_%5E3-%28%3B%25e-T@sfdev3082457-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc example (Process Mining)
"sql_connection_string_template": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='***';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
"sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server"
Default and optional DB names for Automation Suite services
  "orchestrator": "AutomationSuite_Orchestrator",
  "orchestrator_ta": "AutomationSuite_Orchestrator",
  "asrobots": "AutomationSuite_Orchestrator",
  "orchestrator_upd": "AutomationSuite_Platform",
  "platform": "AutomationSuite_Platform",
  "test_manager": "AutomationSuite_Test_Manager",
  "automation_ops": "AutomationSuite_Platform",
  "automation_hub": "AutomationSuite_Automation_Hub",
  "insights": "AutomationSuite_Insights",
  "task_mining": "AutomationSuite_Task_Mining",
  "dataservice": "AutomationSuite_DataService",
  "aicenter": "AutomationSuite_AICenter",
  "documentunderstanding": "AutomationSuite_DU_Datamanager",
  "processmining_airflow": "AutomationSuite_Airflow",
  "processmining_metadata": "AutomationSuite_ProcessMining_Metadata",
  "processmining_warehouse": "AutomationSuite_ProcessMining_Warehouse",
  "apps": "AutomationSuite_Apps",
Note:
If you you want to override the connection string for any of the services above, set the sql_connection_str for that specific service.
You still have to manually create these databases before running the installer.
Overriding the default connection string for Orchestrator and the platform
  "orchestrator": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomOrchDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "platform": {
    "sql_connection_str": "Server=tcp:sfdev1804627-c83f074b-sql.database.windows.net,1433;Initial Catalog=CustomIDDB;Persist Security Info=False;User Id=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;Password=***;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;"
  "orchestrator": {
  "platform": {
To override the database connection strings for other products, set the sql_connection_str in the corresponding product blocks. The connection string should have a format supported by the respective product.
Example for setting database connection string for AI Center
aicenter.sql_connection_strAI Center JDBC connection string (Refer below for the JDBC format)
Note:
Make sure the JDBC connection string has the format in the following sample:
"aicenter": {
    "enabled": true,
    "sql_connection_str": "jdbc:sqlserver://sfdev1804627-c83f074b-sql.database.windows.net;database=aicenter;user=testadmin@sfdev1804627-c83f074b-sql.database.windows.net;password=TFgID_9GsE7_P@srCQp0WemXX_euHQZJ"
"aicenter": {
    "enabled": true,
Sample Document Understanding connection string
"documentunderstanding": {
"enabled": true,
"sql_connection_str": "" // dotnet connection string,
"datamanager": {
 "sql_connection_str": "" // odbc connection string
"enabled": true,
"datamanager": {
Note:
The data manager SQL connection string is optional only if you want to overwrite the default with your own.
Handwriting is always enabled for online installation.
The default value for max_cpu_per-pod is 2, but you can adjust it according to your needs.
Sample Process Mining connection string
"processmining": {
    "enabled": true,
    "warehouse": {
        "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='***';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
	"sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
        "master_sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://testadmin%40sfdev4515230-sql.database.windows.net:07%3Cl%5Bxj-%3D~%3Az%60Ds%26nl@sfdev4515230-sql.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
    "sql_connection_str": "Server=tcp:sfdev4515230-sql.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Metadata;User Id=testadmin@sfdev4515230-sql.database.windows.net;Password='***';Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
    "enabled": true,
    "warehouse": {
Important:
Note that the names for template PYODBC connection string sql_connection_string_template_sqlalchemy_pyodbc and the PYODBC connection string sqlalchemy_pyodbc_sql_connection_str used when you bring your own database are different. Also connection string names are different for the template SQL sql_connection_string_template and sql_connection_str used when you bring your own database.
Important:
If you bring your own database and you configured this using the sql_connection_str and sqlalchemy_pyodbc_sql_connection_str connection strings in the processmining section of the input.jsonfile, the template connection strings sql_connection_string_template and sql_connection_string_template_sqlalchemy_pyodbc are ignored if specified.
Important:
MultiSubnetFailover=True is not supported. Make sure to remove MultiSubnetFailover=True from any of the Process Mining connection strings.
Note:
Depending on the app_security_mode setting either a new SQL user is created for every Process Mining app by the system (app_security_mode="system_managed"), or a single SQL user account is created that is used for all process apps (app_security_mode="single_account"). Note that app_security_mode="system_managed" is the default setting, and that this requires advanced permissions for the database user. See Configuring process app security.
  • Scenario: setup with Kerberos authentication.
"processmining": {
    "enabled": true,
    "warehouse": {
        "sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
        "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes",
        "master_sql_connection_str": "Server=tcp:assql2019.autosuitead.local,1433;Initial Catalog=master;Persist Security Info=False;Integrated Security=true;MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=yes"
"processmining": {
    "enabled": true,
    "warehouse": {
  • Scenario: Metadata database and data warehouse use separate SQL server (Non-Kerberos authentication).
"processmining": {
    "enabled": true,
    "warehouse": {
      "sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=AutomationSuite_ProcessMining_Warehouse;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
      "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration1.database.windows.net:1433/AutomationSuite_ProcessMining_Warehouse?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES",
      "master_sql_connection_str": "Server=tcp:uipath-integration1.database.windows.net,1433;Initial Catalog=master;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;"
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://userid:password@uipath-integration2.database.windows.net:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES"
    "sql_connection_str": "Server=tcp:uipath-integration2.database.windows.net,1433;Initial Catalog=AutomationSuite_Airflow;Persist Security Info=False;User Id=userid;Password='password';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=True;Connection Timeout=30;Max Pool Size=100;",
"processmining": {
    "enabled": true,
    "warehouse": {
  • Scenario: using custom app_security_mode.
"processmining": {
    "enabled": true,
    "app_security_mode": "system_managed",
    "warehouse": {
    "sqlalchemy_pyodbc_sql_connection_str": "mssql+pyodbc://:@assql2019.autosuitead.local:1433/AutomationSuite_Airflow?driver=ODBC+Driver+17+for+SQL+Server&TrustServerCertificate=YES&Encrypt=YES&Trusted_Connection=YES"
"processmining": {
    "enabled": true,
    "warehouse": {
SQL authentication​
Azure Active Directory based access to SQL from AKS​
You may choose to access Microsoft SQL server via Azure Active Directory from AKS cluster. The following example shows some connections strings using the AAD access method:
  "sql_connection_string_template": "Server=tcp:sfdev3888449-sql.database.windows.net,1433;Authentication=Active Directory Service Principal;Initial Catalog=DB_NAME_PLACEHOLDER;Persist Security Info=False;User Id=5c6b8ff1-efb4-48ca-a530-f744f1d438df;Password='I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2';MultipleActiveResultSets=False;Encrypt=True;TrustServerCertificate=False;Connection Timeout=30;Max Pool Size=100;",
  "sql_connection_string_template_jdbc": "jdbc:sqlserver://sfdev3888449-sql.database.windows.net;authentication=ActiveDirectoryServicePrincipal;database=DB_NAME_PLACEHOLDER;user=5c6b8ff1-efb4-48ca-a530-f744f1d438df;password={I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2};encrypt=true;trustServerCertificate=false;hostNameInCertificate=*.database.windows.net;loginTimeout=30;",
  "sql_connection_string_template_odbc": "SERVER=sfdev3888449-sql.database.windows.net;Authentication=ActiveDirectoryServicePrincipal;DATABASE=DB_NAME_PLACEHOLDER;DRIVER={ODBC Driver 17 for SQL Server};UID=5c6b8ff1-efb4-48ca-a530-f744f1d438df;PWD={I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2};Encrypt=yes;TrustServerCertificate=no;Connection Timeout=30;hostNameInCertificate=sfdev3888449-sql.database.windows.net",
  "sql_connection_string_template_sqlalchemy_pyodbc": "mssql+pyodbc://5c6b8ff1-efb4-48ca-a530-f744f1d438df:I5V8Q~srSTWf0onUYeHLK..qLO69pP7MZ3KIMaB2@sfdev3888449-sql.database.windows.net:1433/DB_NAME_PLACEHOLDER?driver=ODBC+Driver+17+for+SQL+Server&authentication=ActiveDirectoryServicePrincipal",
Connect
Need help? Support
Want to learn? UiPath Academy
Have questions? UiPath Forum
Stay updated
