- 入门指南
- 权限
- 以如下身份开始
- 管理控制台
- 工作区
- 探索
- 提交新条目
- 仪表板
- 我的任务
- 通知
- 电子邮件通知
- 资源
- Process Mining 集成
- Studio Integration
- Task Capture 集成
- Automation Hub - Automation Cloud 集成
- Automation Hub - Maestro 集成
- 关于流程存储库
- 将解决方案链接到业务流程
- Creating and editing process maps
- Managing process map versions
- Commenting on process maps
- Automation Hub - Task Mining 集成
- 自动化商店
- 其他资源
请注意,此内容已使用机器翻译进行了部分本地化。
新发布内容的本地化可能需要 1-2 周的时间才能完成。
Automation Hub 用户指南
Access to managing process map versions depends on the cloud platform you use. For details, refer to Feature availability.
Process maps support versioning so you can track changes over time, document what changed in each version, and restore previous states when needed.
Saving a new version
- Open the process map in the process map editor.
- 选择“保存”。
- Select Save as new version.
- Enter a description of what changed in this version.
- 选择“保存”。
A confirmation toast shows the new version number. The version is added to the versions panel.
Viewing version history
- Open the Versions panel from the right-side toolbar.
All saved versions are listed with their version number and description.
Restoring a previous version
- Select the version you want to restore.
- Select Restore.
The restored version becomes the new current version.
