Gerar-Conector do uipathctl SO
Description​
Generate configuration files for Dex connectors. For a complete list of valid connector types and more information about each field, see Dex documentation.
uipathctl sso generate-connector [flags]
Exemplos​
Generate an empty configuration for an LDAP connector:
  uipathctl sso generate-connector -t ldap
Opções​
  -h, --help                  help for generate-connector
  -t, --type connector-type   the type of connector (default ldap)
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
