uipathctl manifest render
Description​
Carregue a configuração encontrada no PATH, e renderize-a no stdout.
uipathctl manifest render PATH [flags]
Opções​
  -h, --help                   help for render
--include-config         include cluster wide config in the diff
--include-dependencies   include dependencies in the diff
  -o, --output output          output format. one of [json,yaml] (default yaml)
Opções herdadas de comandos pai​
  • Description​
  • Opções​
  • Opções herdadas de comandos pai​
