uipathctl config additional-ca-certificates get
Description​
Obtenha o pacote de certificados de CA adicionais atual observado no cluster no formato pem.
O comando utiliza como padrão o contexto atual no arquivo kubeconfig . Se o sinalizador --kubeconfig estiver definido, ele usará o arquivo kubeconfig especificado pelo sinalizador.
uipathctl config additional-ca-certificates get [flags]
Exemplos​
        # Get the additional ca certificates bundle from the cluster
        # Get the additional ca certificates bundle from the cluster with additional certificate information
        uipathctl config additional-ca-certificates get --show-details
        # Get the additional ca certificates bundle from the cluster identified by the current context in the kubeconfig file
        uipathctl config additional-ca-certificates get --kubeconfig cluster.kubeconfig
Opções​
  -h, --help           help for get-additional-ca-certificates
--show-details   if true, additional ca certificate information will be printed
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
