Identity add-host-admin do uipathctl
Description​
Adicione ou atualize um administrador do host com as credenciais fornecidas. O comando utiliza como padrão o contexto atual no arquivo kubeconfig . Se o sinalizador --kubeconfig estiver definido, ele usará o arquivo kubeconfig especificado pelo sinalizador.
uipathctl identity add-host-admin [flags]
Exemplos​
        # Add host admin with the provided username and password in cluster
        uipathctl identity add-host-admin --username newadmin --password password
        # Add host admin with the provided username, password and email in cluster
        uipathctl identity add-host-admin --username newadmin --email email --password password
        # Add host admin with the provided username and password in the cluster identified by the current context in the kubeconfig file
        uipathctl identity add-host-admin --username newadmin --password password --kubeconfig cluster.kubeconfig
Opções​
  -e, --email string      host admin email
  -h, --help              help for add-host-admin
  -p, --password string   host admin password
  -u, --username string   host admin username
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
