- Visão geral
- Pré-instalação
- Instalação
- Administração de cluster
- Backup e restauração
- instantâneo do uipathctl
- uipathctl snapshot delete
- uipathctl snapshot list
- uipathctl snapshot restore
- Gerenciamento de certificados
- A identidade do uipathctl get-saml-certificate
- Atualização
- Autenticação
- Monitoramento e alertas
- Configuração do uipathctl
- alertas de configuração do uipathctl
- alertas de configuração do uipathctl add-email
- Recurso uipathctl
- Relatório de recursos do uipathctl
- Solução de problemas
Adicione o receptor de email para o AlertManager.
uipathctl config alerts add-email [flags]
Exemplo
# Adds new email receiver based on parameters passed in command
uipathctl config alerts add-email --name test --to "admin@example.com" --from "admin@example.com" --smtp "server.mycompany.com:443" --username admin --password "somepassword" --require-tls --ca-file "file path too rootCA" --cert-file "file path too server certificate" --key-file "file path too server key file"
Opções
--ASEA Boolean flag to denote whether the cluster is ASEA or not
--ca-file string File path containing the CA certificate of the SMTP server. This parameter is optional if the CA is private
--cert-file string File path containing the certificate of the SMTP server. This parameter is optional if the certificate is private
--from string The sender's email address
-h, --help help for add-email
--key-file string File path containing the private key of the certificate for the SMTP server. This parameter is required if the certificate is private
--name string Name of the email configuration
--password string SMTP authentication Password
--require-tls Boolean flag to denote that TLS is enabled at the SMTP server (default true)
--send-resolved Boolean flag to denote whether to send email on resolved alert (default true)
--smtp string SMTP server URL or IP, including port
--to string Receiver's email address
--username string SMTP authentication Username
Opções herdadas de comandos pai
