Manifesto do uipathctl list-applications
Description​
Carrega o arquivo de configuração encontrado no parâmetro e lista os aplicativos criados com base nele. A configuração do Runtime é usada para determinar quais aplicativos são necessários. A saída está sempre em formato tabular. Por padrão, a lista é classificada em ordem alfabética.
uipathctl manifest list-applications PATH [flags]
Exemplos​
        # List the applications which are installed based on the configuration found in input.json
        uipathctl manifest list-applications input.json
        # List the applications which are installed based on the configuration found in input.json.
        # Sort them by the order in which they need to be installed based on dependencies between them.
        uipathctl manifest list-applications input.json --sort-by topological
        # List the applications without headers
        uipathctl manifest list-applications input.json --no-headers
        # Override the initial list of enabled components
        uipathctl manifest list-applications input.json --override gatekeeper,redis
Opções​
  -h, --help                 help for list-applications
--is-required string   to check whether the component needs to install
--no-headers           if true, print the output without headers
--override strings     optional list of components to override the components enabled in input.json file
--sort-by sortBy       if set, sort the output by the given criteria. Valid values are: [alphabetical, topological] (default alphabetical)
Opções herdadas de comandos pai​
  • Description​
  • Exemplos​
  • Opções​
  • Opções herdadas de comandos pai​
