Als geschäftlicher Prüfer starten
After successfully logging in, you, as a Business Reviewer need to focus on pushing forward automations created by Citizen Developer Self Users and select the ones worth being endorsed for a Technical Review. To do this check the Automation Pipeline > Review page and review automations that are awaiting the business review.
Verbinden
Benötigen Sie Hilfe? Support
