2022.4
Automation Hub User Guide
Last updated Oct 17, 2024
Orchestrator Connection
With an active Orchestrator connection, you will be able to consume automations. When you choose to GET an automation from the Automation Store, the package corresponding to that Automation will be sent to your Personal Workspace from the connected Orchestrator.
To check your connection, access Platform Setup from Admin Console in Automation Hub, and you'll see an overview that contains:
  • Brief information about what is an Orchestrator Connection
  • Connection Status
    Note: The Orchestrator connection is set up between the Automation Hub and Orchestrator instance that sits on the same Automation suite tenant.
