- Getting started
- Best practices
- Tenant
- About the Tenant Context
- Searching for Resources in a Tenant
- Managing Robots
- Connecting Robots to Orchestrator
- Storing Robot Credentials in CyberArk
- Storing Unattended Robot Passwords in Azure Key Vault (read only)
- Storing Unattended Robot Credentials in HashiCorp Vault (read only)
- Storing Unattended Robot Credentials in AWS Secrets Manager (read only)
- Deleting Disconnected and Unresponsive Unattended Sessions
- Robot Authentication
- Robot Authentication With Client Credentials
- SmartCard Authentication
- Configuring automation capabilities
- Audit
- Settings - Tenant Level
- Resource Catalog Service
- Folders Context
- Automations
- Processes
- Jobs
- About Jobs
- Managing Jobs
- Job States
- Working with long-running workflows
- Running Personal Remote Automations
- Process Data Retention Policy
- Triggers
- Logs
- Monitoring
- Queues
- Assets
- Storage Buckets
- Orchestrator testing
- Other Configurations
- Integrations
- Host administration
- About the host level
- Managing system administrators
- Managing tenants
- Configuring system email notifications
- Audit logs for the host portal
- Maintenance Mode
- Organization administration
- Troubleshooting
Run personal automations from Orchestrator by launching jobs manually or using triggers
This article walks RPA developers, citizen developers, and business users through the steps for running personal automations from Orchestrator by manually launching a job via the Start Job functionality or by using a trigger.
Prerequisites:
- You or an administrator previously deployed the background process you want to execute to a folder you have access to.
- An administrator allocated the unattended infrastructure for running jobs by adding a machine template object to the folder.
Start a Job as Yourself
Navigate to Automations > Jobs in the folder the background process resides in.
Select Start. The Start Job window is displayed.
From the Process Name drop-down, select the process you want to execute.
From the Account drop-down, select Run as Myself (Personal automation) to execute the job under your own identity. Note that this option is available only for background processes.
Configure the other settings following the instructions provided in the Starting a job documentation.
Select Start to start the job. The job is displayed as Pending on the Jobs page until a robot is available to pick it up.
Figure 1. Starting a job
Configure a Trigger to Launch Jobs as Yourself
Navigate to Automations > Triggers in the folder the background process resides in.
Select Add a new trigger. The Create trigger window is displayed.
On the Name field, give your trigger a meaningful name.
From the Process Name drop-down, select the process you want that trigger to launch jobs for.
From the Account drop-down, select Run as Myself (Personal automation) to execute the jobs launched by the trigger under your own identity. Note that this option is available only for background processes.
Configure the other settings following the instructions provided in the Managing triggers documentation.
Select Add to add the trigger. The trigger is displayed in the Triggers page and will launch a job under your own identity according to the trigger configuration.
Figure 2. Adding a trigger
